Help Center/
API Gateway/
User Guide (ME-Abu Dhabi Region)/
Monitoring & Analysis/
API Monitoring/
Creating Alarm Rules
Updated on 2023-05-09 GMT+08:00
You can create alarm rules to monitor the status of your APIs.
An alarm rule consists of a rule name, monitored objects, metrics, alarm thresholds, monitoring interval, and notification.
An API has been called.
- Log in to the APIG console.
- Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
- Click a group name.
- On the Monitoring area of the APIs tab, click More to access the Cloud Eye console. Then create an alarm rule. For details, see section "Creating an Alarm Rule" in the Cloud Eye User Guide.
Parent topic: API Monitoring
