Comparing Versions
The new API Gateway (APIG) console is available since April 2, 2023. The following table lists the differences between the old and new consoles.
       Difference  |
       Old  |
       New  |
       Two-factor authentication  |
       Not supported  |
       Supported  |
       Configuration of retries for HTTP&HTTPS backend services  |
       Not supported  |
       Supported  |
       API import  |
       For registering APIs  |
       For registering APIs or creating API groups  |
       API debugging with a custom body  |
       Not supported  |
       Supported  |
       API details page  |
       Average  |
       Highly integrated  |
       API topology  |
       Supported  |
       Not supported  |
       Visual display of API policies  |
       Not supported  |
       Supported  |
       Creating policy by script  |
       Not supported  |
       Supported  |
       Plug-in type  |
       CORS, HTTP response header management, request throttling  |
       CORS, HTTP response header management, request throttling 2.0, Kafka log push, circuit breaker. These plug-ins are managed together with traditional policies.  |
       SSL certificate management  |
       Not supported  |
       Supported  |
       Creating server groups for load balance channels  |
       Not supported (VPC channels)  |
       Supported  |
       Health check switch for load balance channels  |
       Supported  |
       Display of standby nodes and statuses for load balance channels  |
       Supported  |
       Apps  |
       Supported  |
       Now called "credentials"  |
       Credential quota policies  |
       Not supported  |
       Supported  |
       Access control policies  |
       Not supported  |
       Supported  |
       API monitoring  |
       Provided on the Dashboard page  |
       Now called "API Monitoring"  |
       Subdomain name  |
       Supported  |
       Now called "debugging domain name"  |
       Variable management  |
       Variables  |
       Now called Environment Variables  |
       Gateway selection in left navigation pane  |
       Not supported  |
       Supported  |
       Bandwidth monitoring  |
       Not supported  |
       Supported  |
       Importing CCE workloads  |
       Not supported  |
       Supported  |
       Gateway tags  |
       Not supported  |
       Supported  |
       Microservice load balance channels  |
       Not supported  |
       Supported  |
       Account ID-based access control  |
       Not supported  |
       Supported  |
       Cloning APIs  |
       Not supported  |
       Supported  |
       custom_log  |
       Not supported  |
       Supported  |
       Third-party authentication policy  |
       Not supported  |
       Supported  |
       gzip compression  |
       Not supported  |
       Supported  |
       gRPC protocol  |
       Not supported  |
       Supported  |
       Server-sent events (SSE) transmission  |
       Not supported  |
       Supported  |
       API policy cloning  |
       Not supported  |
       Supported  |
       OpenAPI 3.0  |
       Not supported  |
       Supported  |
       Client request customization  |
       Not supported  |
       Supported  |
       HTTP-to-HTTPS auto redirection  |
       Not supported  |
       Supported  |
       CA certificate  |
       Not supported  |
       Supported  |
