Help Center>
API Gateway>
User Guide (ME-Abu Dhabi Region)>
FAQs>
API Publishing>
How Do I Specify an Environment for API Debugging?
Updated on 2023-05-09 GMT+08:00
APIG debugs APIs in a specific debugging environment. After debugging is completed, you need to publish your API in an environment, and use code or postman to add the X-Stage header to specify the environment where you want to call the API.
Parent topic: API Publishing
