Help Center>
Virtual Private Cloud>
FAQs>
Security>
Are the Security Group Rules Considered the Same If All Parameters Except Their Description Are the Same?
Updated on 2022-06-24 GMT+08:00
Yes. You cannot add or import a security group rule that has the same parameters but a different description than an existing rule in the security group.
Parent topic: Security
Security FAQs
- Are the Security Group Rules Considered the Same If All Parameters Except Their Description Are the Same?
- Why Is Outbound Access on TCP Port 25 Blocked?
- How Do I Know the Instances Associated with a Security Group?
- Why Can't I Delete a Security Group?
- Can I Change the Security Group of an ECS?
- How Do I Configure a Security Group for Multi-Channel Protocols?
- Does a Modified Security Group Rule or a Network ACL Rule Take Effect Immediately for Existing Connections?
- Why Are Some Ports Inaccessible?
- Why Is Access from a Specific IP Address Still Allowed After a Network ACL Rule That Denies the Access from the IP Address Has Been Added?
- Why Do My Security Group Rules Not Take Effect?
Chatbotmore
