Viewing the Vulnerability List
This section describes how to view the list of detected vulnerabilities.
An account and its password have been obtained for logging in to the management console.
- Choose Security > Vulnerability Scan Service > Dashboard.
- On the right of the Vulnerability List area, click View to go to the Vulnerability List page.
NOTE: You can expand the All statuses or Advanced Search drop-down box to filter vulnerabilities to view. If you click Advanced Search, first set the discovery time, select items from All vulnerabilities drop-down list, set the vulnerability level, and then click Search. Click Reset to clear the search criteria.
Figure 1 Vulnerability List
Table 1 Vulnerability list parameters Parameter
Vulnerability ID
ID of a vulnerability You can click a vulnerability ID to view the vulnerability details.
Target Network Address
Page where the vulnerability is detected
Discovered
Time when a vulnerability is detected
Level
Level of a vulnerability. Possible values are:
- High: high-risk
- Medium: medium-risk
- Low: low-risk
- Info
Type
Type of a vulnerability, including SQL injection, reflected XSS, and cross-site request forgery
Status
Status of a vulnerability. Possible values are:
- Not fixed
- Fixed
- Ignored
