Custom Policies
Custom policies can be created to supplement the system-defined policies of NES.
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a policy in the JSON format from scratch or based on an existing policy.
For details, see Creating a Custom Policy. The following section contains examples of common NES custom policies.
- On the management console homepage, click Identity and Access Management.
- In the navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy.
- On the Create Custom Policy page, set the policy name, view, content, and description, then click OK.
- Policy Name: Enter a custom policy name, for example, partial NES permissions.
- Policy View: Select JSON.
- Policy Content: Enter the policy content based on the template. For example, to create a node, query a single node, and obtain node monitoring information, copy the following content:
{ "Version": "1.1", "Statement": [ { "Action": [ "bcs:nesNode:create", "bcs:nesNode:get", "bcs:nesNode:getMetric" ], "Effect": "Allow" } ] }Table 1 Policy content parameters Parameter
Value
Version
Policy version
Fixed to 1.1.
Statement
Effect
Whether the actions are allowed
- Allow
- Deny
Action
Operations to be performed on NES
Each action name is in the format of Service name:Resource type:Operation and cannot be customized. Table 2 lists the fine-grained permissions supported by NES. After you set any action, the permissions for the action will be granted to the IAM user.
Table 2 Action description Action
Action Description
bcs:nes:getSummary
Obtaining the Overview Information
bcs:nes:listNetwork
Obtaining the Network Types
bcs:nes:listNetworkFlavor
Obtaining Available Specifications
bcs:nesNode:listFlavor
Obtaining Available Specifications for Node Scaling
bcs:nesNode:list
Obtaining All Nodes on a Specified Network
bcs:nesNode:create
Creating a Node
bcs:nesNode:get
Querying a Node
bcs:nesNode:delete
Deleting a Node
bcs:nesNode:update
Updating a Node
Obtaining the Node Monitoring Information
bcs:nesNode:getStatistic
Obtaining the API Calling Information of a Node in a Specified Period
bcs:nesNode:getStatus
Obtaining the Status of a Staking Node in a Specified Period
bcs:nesNode:downloadCert
Downloading Certificates
bcs:nesAPIKey:create
Creating an API Key
bcs:nesAPIKey:list
Obtaining All API Keys of a User
bcs:nesAPIKey:delete
Deleting an API Key
bcs:nesAPIKey:update
Updating an API Key
bcs:nesNode:validateRelays
Verifying the Address of Relays
bcs:nesNode:updateRelays
Updating the Address of Relays
