Changing or Resetting the Password for User admin of Manager
User admin is the system administrator account of Manager. You are advised to periodically change the password on Manager to improve system security.
If the password is lost, reset the password by referring to Resetting the Password for User admin.
Changing the Password for User admin
You can change the password of user admin on Manager only for clusters with Kerberos authentication enabled and clusters with Kerberos authentication disabled but the EIP function enabled.
User admin is required for login.
- Move your cursor over Hello, admin in the upper right corner of the page.
On the user account drop-down menu, choose Change Password.
- Set Old Password, New Password, and Confirm Password, and click OK.
- Log in to the Master1 node.
- (Optional) To change the password as user omm, run the following command to switch the user:
sudo su - omm
- Run the following command to switch to the client directory, for example, /opt/Bigdata/client:
cd /opt/Bigdata/client
- Run the following command to configure environment variables:
source bigdata_env
- Run the following command to log in to the console as user kadmin/admin:
kadmin -p kadmin/admin
The default password of user kadmin/admin is Admin@123, which will expire upon your first login. Change the password as prompted and keep the new password secure.
- Run the following command to reset the password of user admin:
cpw admin
