Updated on 2022-09-23 GMT+08:00
Log Maintenance Suggestions
Operation logs help discover exceptions such as illegal operations and login by unauthorized users. The system records important operations in logs. You can use operation logs to locate problems.
Checking Logs Regularly
Check system logs periodically and handle exceptions such as unauthorized operations or logins in a timely manner.
Backing Up Logs Regularly
The audit logs provided by FusionInsight Manager and cluster record the user activities and operations. You can export the audit logs on FusionInsight Manager. If there are too many audit logs in the system, you can configure dump parameters to dump audit logs to a specified server to ensure that the cluster nodes disk space is sufficient.
Maintenance Owner
Network monitoring engineers and system maintenance engineers
