Help Center > > User Guide> FusionInsight Manager Operation Guide (Applicable to 3.x)> Security Management> Security Hardening> Configuring Communication Authentication for Storm Processes
Updated at: Mar 25, 2021 GMT+08:00
The authentication function is disabled by default during the communication of Storm service processes. You can decide whether to enable this function based on the specific service scenario.
Page access: On FusionInsight Manager, choose Cluster > Name of the desired cluster > Services > Storm > Configurations. Click All Configurations. Enter the parameter name in the search box.
Restart the corresponding service after configuration.
Table 1 Parameter description
Item
Default Value
storm.messaging.netty.authentication
Indicates whether to enable the Netty communication authentication framework for service processes. Netty communication authentication is disabled by default, but you can enable it for a specific topology. If this parameter is configured on the client, the client configuration prevails. Otherwise, the cluster configuration prevails.
Exercise caution when you enable the Netty communication authentication framework because this will affect the topology throughput.
false
Did you find this page helpful?
Submit successfully!
Thank you for your feedback. Your feedback helps make our documentation better.
Failed to submit the feedback. Please try again later.
Which of the following issues have you encountered?
Please complete at least one feedback item.
Content most length 200 character
Content is empty.
OK Cancel
