Changing the Password for the LDAP Administrator
![](https://support.huaweicloud.com/intl/en-us/usermanual-mrs/public_sys-resources/note_3.0-en-us.png)
This section applies only to MRS 3.1.0. For later versions, see Modifying OMS Service Configuration Parameters.
It is recommended that the administrator periodically changes the passwords of LDAP administrator accounts cn=krbkdc,ou=Users,dc=hadoop,dc=com and cn=krbadmin,ou=Users,dc=hadoop,dc=com to improve the system O&M security.
Impact on the System
- You need to restart the KrbServer service after changing the password.
- After the password is changed, check whether the LDAP administrator accounts cn=krbkdc,ou=Users,dc=hadoop,dc=com and cn=krbadmin,ou=Users,dc=hadoop,dc=com are locked, run the following command on the active management node of the cluster to check whether krbkdc is locked (the method for user krbadmin is similar):
OLdap port number obtaining method:
- Log in to FusionInsight Manager, choose :
- The LDAP Listening Port parameter value is oldap port.
ldapsearch -H ldaps://OMS_FLOAT_ IP address:OLdap port -LLL -x -D cn=krbkdc,ou=Users,dc=hadoop,dc=com -W -b cn=krbkdc,ou=Users,dc=hadoop,dc=com -e ppolicy
Enter the password of the LDAP administrator account krbkdc. The default password is LdapChangeMe@123. If the following message is displayed, the account is locked. For details about how to unlock the account, see Unlocking LDAP Users and Management Accounts.
ldap_bind: Invalid credentials (49); Account locked
You have obtained the management node IP address.
- Log in to the active management node as user omm with the IP address of the active management node.
- Run the following command to go to the related directory:
cd ${BIGDATA_HOME}/om-server/om/meta-0.0.1-SNAPSHOT/kerberos/scripts
- Run the following command to change the password of the LDAP administrator account:
./okerberos_modpwd.sh
Enter the old password and then enter a new password twice.
The password must meet the following complexity requirements:
- Contains 16 to 32 characters.
- Contains at least three types of the following: uppercase letters, lowercase letters, numbers, spaces, and special characters (`~!@#$%^&*()-_=+|[{}];,<.>/?).
- Cannot be the same as the current password.
If the following information is displayed, the password is changed.
Modify kerberos server password successfully.
- Log in to FusionInsight Manager, click Cluster, click the name of the desired cluster, and choose Services > KrbServer. On the displayed page, choose More > Restart Service.
Enter the password and do not select Restart upper-layer services. Click OK to restart the KrbServer service.
