Enabling and Disabling Permission Verification on Cluster Components
HDFS and ZooKeeper verify the permission of users who attempt to access the services in both security and normal clusters by default. Users without related permission cannot access resources in HDFS and ZooKeeper. When the cluster is deployed in normal mode, HBase and YARN do not verify the permission of users who attempt to access the services by default. All users can access resources in HBase and YARN.
Based on actual service requirements, administrators can enable permission verification on HBase and YARN or disable permission verification on HDFS and ZooKeeper in normal clusters.
Impact on the System
After the enabling and disabling operations, the service configuration will expire. You need to restart the corresponding service for the configuration to take effect.
Enabling Permission Verification on HBase
- Click Cluster, click the name of the desired cluster, choose Services > HBase, and click Configurations.
- Click All Configurations.
- Search for parameters hbase.coprocessor.region.classes, hbase.coprocessor.master.classes, and hbase.coprocessor.regionserver.classes.
Add the coprocessor parameter org.apache.hadoop.hbase.security.access.AccessController to the end of the values of the preceding parameters, and use a comma (,) to separate the values from those of the original coprocessors. The hbase.coprocessor.region.classes parameter is used as an example.
Figure 1 hbase.coprocessor.region.classes - Click Save, click OK, and wait for message "Operation successful" to display.
Disabling Permission Verification on HBase
![](https://support.huaweicloud.com/intl/en-us/usermanual-mrs/public_sys-resources/note_3.0-en-us.png)
After HBase permission verification is disabled, the existing permission data will be retained. If you want to delete permission information, disable permission verification, enter the HBase shell, and delete table hbase:acl.
Delete the coprocessor parameter org.apache.hadoop.hbase.security.access.AccessController.
Disabling Permission Verification on HDFS
- Click Cluster, click the name of the desired cluster, choose Services > HDFS, and click Configurations.
- Search for parameters dfs.namenode.acls.enabled and dfs.permissions.enabled.
- dfs.namenode.acls.enabled indicates whether to enable HDFS ACL. The default value is true, indicating that the ACL is enabled. Change the value to false.
- dfs.permissions.enabled indicates whether to enable permission check for HDFS. The default value is true, indicating that permission check is enabled. Change the value to false. After the modification, the owner, owner group, and permission of the directories and files in HDFS remain unchanged.
Enabling Permission Verification on YARN
- Click Cluster, click the name of the desired cluster, choose Services > Yarn, and click Configurations.
- Search for parameter yarn.acl.enable.
yarn.acl.enable indicates whether to enable the permission check for YARN.
- In normal clusters, the value is set to false by default to disable permission check. To enable permission check, change the value to true.
- In security clusters, the value is set to true by default to enable authentication.
Figure 2 Setting the yarn.acl.enable parameter - Click Save, click OK, and wait for message "Operation successful" to display.
Disabling Permission Verification on ZooKeeper
- Click Cluster, click the name of the desired cluster, choose Services > ZooKeeper, and click Configurations.
- Search for parameter skipACL.
skipACL indicates whether to skip the ZooKeeper permission check. The default value is no, indicating that permission check is enabled. Change the value to yes.
Figure 3 Setting the skipACL parameter - Click Save, click OK, and wait for message "Operation successful" to display.
