Help Center > > User Guide> FusionInsight Manager Operation Guide> System Configuration> OMS Management> Changing the OMS Database Password
Updated at: Mar 25, 2021 GMT+08:00
Periodically change the password for the OMS data access user to ensure the system O&M security.
Impact on the System
The OMS service needs to be restarted for the password changing to take effect. The FusionInsight Manager is unavailable during the restart.
  1. Choose System > OMS > gaussDB > Change Password on FusionInsight Manager.
  2. Locate the row that contains user omm and click Change Password in the Operation to change the password for the OMS database user.
  3. In the displayed window, enter the password of the current login administrator user and click OK.
  4. Enter the old and new passwords as prompted.
    The password complexity requirements are as follows:
    • The password ranges from 8 to 32 characters.
    • The password must contain at least three types of the following: lowercase letters, uppercase letters, digits, and special characters which can only be ~`!@#$%^&*()-+_=\|[{}];",<.>/?
    • The password cannot be the same as the username or reverse username.
    • The password cannot be the same as the last 20 historical passwords.
  5. Click OK. After the system displays Operation succeeded, click Finish.
  6. Locate the row that contains user omm and click Restart OMS Service in the Operation to restart the OMS database.
  7. In the displayed window, enter the password of the current login administrator user and click OK.
  8. In the dialog box that is displayed, click OK, and then restart the OMS service.
Did you find this page helpful?
Submit successfully!
Thank you for your feedback. Your feedback helps make our documentation better.
Failed to submit the feedback. Please try again later.
Which of the following issues have you encountered?
Please complete at least one feedback item.
Content most length 200 character
Content is empty.
OK Cancel
