Updated on 2023-04-10 GMT+08:00
Configuring Syslog Northbound Parameters
If users need to view alarms and events of a cluster on the unified alarm reporting platform, you can use the Syslog protocol on FusionInsight Manager to report related data to the alarm platform.
If the Syslog protocol is not encrypted, data may be stolen.
  2. Choose System > Interconnection > Syslog.
  3. Toggle on Syslog Service.
    The Syslog service is disabled by default. indicates that the service is enabled.
  4. Set northbound parameters according to Table 1.
    Table 1 Syslog interconnection parameters
    Parameter Area
    Syslog Protocol
    Server IP Address Mode
    Specifies the IP address mode of the interconnected server. The value can be IPV4 or IPV6.
    Server IP Address
    Specifies the IP address of the interconnected server.
    Server Port
    Specifies the port number for interconnection.
    Protocol
    Specifies the protocol type. The options are as follows:
    • TCP
    • UDP
    Severity Level
    Specifies the severity of the reported message. The options are as follows:
    • Emergency
    • Alert
    • Critical
    • Error
    • Warning
    • Notice
    • Informational (default value)
    • Debug
      Severity Level and Facility determine the priority of the sent message.
      Priority = Facility × 8 + Severity Level
      For details about the values of Severity Level and Facility, see Table 2.
    Facility
    Specifies the module where the log is generated. For details about the available values of this parameter, see Table 2. Default value local use 0 (local0) is recommended.
    Identifier
    Specifies the product ID. The default value is FusionInsight Manager.
    The identifier can contain a maximum of 256 characters, including letters, digits, underscores (_), periods (.), hyphens (-), spaces, and the following special characters: | $ { }
    Report Message
    Report Format
    Specifies the message format of the alarm report. For details, see the help information on the page.
    The report format can contain a maximum of 1024 characters, including letters, digits, underscores (_), periods (.), hyphens (-), spaces, and the following special characters: | $ { }
    For details about each field in the report format, see Table 3.
    Alarm Type
    Specifies the type of the alarm to be reported.
    Alarm Severities
    Specifies the level of the alarm to be reported.
    Uncleared Alarm Reporting
    Periodic Uncleared Alarm Reporting
    Specifies whether to report uncleared alarms in a specified period. You can toggle on or off the function. The function is toggled off by default.
    Report Interval (min)
    Specifies the interval for periodically reporting uncleared alarms. This parameter is valid only when Periodic Uncleared Alarm Reporting is enabled. The default value is 15, in minutes. The value ranges from 5 to 1440 (one day).
    Heartbeat Settings
    Heartbeat Reporting
    Specifies whether to periodically report Syslog heartbeat messages. You can toggle on or off the function. The function is toggled off by default.
    Heartbeat Interval (minutes)
    Specifies the interval for periodically reporting heartbeat messages. This parameter is valid only when Heartbeat Reporting is enabled. The default value is 15, in minutes. The value ranges from 1 to 60.
    Heartbeat Packet
    Specifies the heartbeat message to be reported. This parameter is valid when Heartbeat Reporting is toggled on and cannot be left blank. The value can contain a maximum of 256 characters, including digits, letters, underscores (_), vertical bars (|), colons (:), spaces, commas (,), and periods (.).
    After the periodic heartbeat packet function is enabled, packets may be interrupted during automatic recovery of some cluster error tolerance (for example, active/standby OMS switchover). In this case, wait for automatic recovery.
  5. Click OK.
Related Information
Table 2 Numeric codes of Severity Level and Facility
Severity Level
Facility
Numeric Code
Emergency
kernel messages
0
Alert
user-level messages
Critical
mail system
2
Error
system daemons
3
Warning
security/authorization messages (note 1)
4
Notice
messages generated internally by syslog
5
Informational
line printer subsystem
6
Debug
network news subsystem
7
UUCP subsystem
8
clock daemon (note 2)
9
10
FTP daemon
11
NTP subsystem
12
log audit (note 1)
13
log alert (note 1)
14
15
local use 0~7 (local0 ~ local7)
16 to 23
Table 3 Report format information fields
Information Field
dn
Cluster name
id
Alarm ID
name
Alam name
serialNo
Alarm serial number
The serial numbers of the fault alarms and the corresponding clear alarms are the same.
category
Alarm type. The options are as follows:
  • 0: fault alarm
  • 1: clear alarm
  • 2: event
occurTime
Time when the alarm was generated
clearTime
Time when this alarm was cleared
isAutoClear
Whether an alarm is automatically cleared. The options are as follows:
  • 1: yes
  • 0: no
locationInfo
Location where the alarm was generated
clearType
Alarm clearance type. The options are as follows:
  • -1: not cleared
  • 0: automatically cleared
  • 2: manually cleared
level
Severity. The options are as follows:
  • 1: critical alarm
  • 2: major alarm
  • 3: minor alarm
  • 4: warning alarm
cause
Alarm cause
additionalInfo
Additional information
object
Alarm object
