Updated on 2023-07-11 GMT+08:00
Clearing Queue Configurations
You can clear the configurations of a queue on FusionInsight MRS Manager when the queue does not need resources of a resource pool or the resource pool needs to be disassociated from the queue. Clearing queue configurations cancels the resource capacity policy of the queue in the resource pool.
You have changed the default resource pool of the queue to another one. If a queue is to be disassociated from a resource pool, this resource pool cannot serve as the default resource pool of the queue. For details, see Modifying Queue Resources.
  2. Choose Tenant Resources > Dynamic Resource Plan.
  3. Select the name of the target cluster from Cluster and select a resource pool from Resource Pool.
  4. Locate the row that contains the target resource name in the Resource Allocation area, and click Clear in the Operation column.
  5. In the displayed dialog box, click OK to clear the queue configurations from the current resource pool.
