Updated on 2022-12-02 GMT+08:00
Restoring Tenant Data
Tenant data is stored on FusionInsight Manager and cluster components. When components are recovered from failures or reinstalled, some configuration data of all tenants may become abnormal. In this case, you need to manually restore the configuration data on FusionInsight Manager.
  1. Log in to FusionInsight Manager and choose Tenant Resources.
  2. In the tenant list on the left, click the target tenant.
  3. Check the tenant data status.
    1. On the Summary page, check Tenant Status. A green icon indicates that the tenant is available and gray indicates that the tenant is unavailable.
    2. Click Resource and check the icons on the left of Yarn and HDFS Storage. A green icon indicates that the resource is available, and gray indicates that the resource is unavailable.
    3. Click Service Associations and check the Status column of the associated services. Normal indicates that the component can provide services for the associated tenant. Not Available indicates that the component cannot provide services for the tenant.
    4. If any of the preceding check items is abnormal, go to 4 to restore tenant data.
  4. Click . In the displayed dialog box, enter the password of the current login user and click OK.
  5. In the Restore Tenant Resource Data window, select one or more components to restore data, and click OK. The system automatically restores the tenant data.
