Overview
The Audit page displays the user operations on Manager. On this page, administrators can view historical user operations on Manager. For details about the audit information, see Audit Logs.
Overview
Log in to FusionInsight Manager and choose Audit. The Audit page displays the operation type, risk level, start time, end time, user, host name, service, instance, and operation result.
![Click to enlarge](https://support.huaweicloud.com/intl/en-us/usermanual-mrs/en-us_image_0000001318467884.png)
- You can select audit logs at the Critical, Major, Minor, or Notice level from the All risk levels drop-down list.
- In Advanced Search, you can set filter criteria to query audit logs.
- You can query audit logs by user management, cluster, service, and health in the Operation Type column.
- In the Service column, you can select a service to query corresponding audit logs.
You can select -- to search for audit logs using all other search criteria except services.
- You can query audit logs by operation result. Value options are All, Successful, Failed, and Unknown.
- You can click
to manually refresh the current page or click
to filter the columns displayed in the page.
- Click Export All to export all audit information at a time. The audit information can be exported in TXT or CSV format.
