Updated on 2022-12-02 GMT+08:00
Log Download
FusionInsight Manager allows you to batch export logs generated on all instances of each service.
  2. Choose O&M > Log > Download.
  3. Select a log download range:
    1. Service: Click and select a service.
    2. Host: Enter the IP address of the host where the service is deployed. You can also click to select the required host.
    3. Click in the upper right corner and configure Start Time and End Time.
  4. Click Download.
    The downloaded log package contains the topology information of the start time and end time, helping you quickly find the log you need.
    The topology file is named in the format of topo_<Topology structure change time>.txt. The file contains the node IP address, host name, and service instances that reside on the node. (OMS nodes are identified by Manager:Manager.)
    Example:
    192.168.204.124|suse-124|DBService:DBServer;KrbClient:KerberosClient;LdapClient:SlapdClient;LdapServer:SlapdServer;Manager:Manager;meta:meta
