Help Center>
MapReduce Service>
User Guide>
FusionInsight Manager Operation Guide (Available for 3.x)>
Cluster>
Managing a Service>
Service Management Operations>
Performing Active/Standby Switchover of a Role Instance
Updated on 2023-12-14 GMT+08:00
Some service roles are deployed in active/standby mode. If the active instance needs to be maintained and cannot provide services, or other maintenance is required, you can manually trigger an active/standby switchover.
- Choose Cluster > Name of the desired cluster > Services.
- Click the specified service name on the service management page.
- On the service details page, expand the More drop-down list and select Perform Role Instance Switchover.
- In the displayed dialog box, enter the password of the current login user and click OK.
- In the displayed dialog box, click OK to perform active/standby switchover for the role instance.
- The Manager component package only supports the active/standby switchover of DBService role instances.
- The HD component package supports the active/standby switchover of the following service role instances: HDFS, YARN, Storm, HBase, and MapReduce.
- When an active/standby switchover is performed for a NameNode on HDFS, a NameService must be set.
- The Porter component package only supports the active/standby switchover of Loader role instances.
- This function cannot be used for other role instances.
Parent topic: Service Management Operations
