Updated on 2023-12-14 GMT+08:00
Overview
Dashboard
Log in to FusionInsight Manager. Choose Cluster, click the name of the desired cluster, and choose Services. The service management page is displayed, including the functional area and service list.
Figure 1 Service management page
Functional Area
In the functional area of the service management page, you can select a view type and filter and search for services by service type. You can use the advanced search to select required services based on the running status and configuration status.
Service List
The service list on the service management page contains all installed services in the cluster. If the tile view is selected, the services will be displayed in pane style. If you select the list view, the services will be displayed in a table.
In this section, the Tile View is used by default.
The service list displays the running status, configuration status, role type, and number of instances of each service. On this page, you can perform some service maintenance tasks, such as starting, stopping, and restarting services.
Table 1 Service running status
Status
Normal
Indicates that the service is running properly.
Faulty
Indicates that the service cannot run properly.
Partially Healthy
Indicates that some enhanced functions of the service are abnormal.
Not started
Indicates that the service is stopped.
Unknown
Indicates that the initial status of the service cannot be detected.
Starting
Indicates that the service is being started.
Stopping
Indicates that the service is being stopped.
Failed to start
Indicates that the service fails to be started.
Failed to stop
Indicates that the service fails to be stopped.
  • If the running status of a service is Faulty, an alarm is generated. Rectify the fault based on the alarm information.
  • HBase, Hive, Spark, and Loader may be in the Subhealthy state.
    • If Yarn is installed but is abnormal, HBase is in the Subhealthy state.
    • If HBase is installed but is abnormal, Hive, Spark, and Loader are in the Subhealthy state.
Table 2 Service configuration status
Status
Synchronized
Indicates that all service parameter settings have taken effect in the cluster.
Expired
Indicates that the latest configuration is not synchronized and does not take effect after the service parameters are modified. You need to synchronize the configurations and restart the services. You can click next to Configuration Status to view expired configuration items.
Failed
Indicates that a communication or read/write exception occurs during the parameter configuration synchronization. Use Synchronize Configuration to rectify the fault.
Synchronizing
Indicates that the service parameter configuration is being synchronized.
Unknown
You can click a service in the service list to perform simple maintenance and management operations on the service, as described in Table 3.
Table 3 Basic maintenance and management
Menu Item on the UI
Start Service
Start a specified service in the cluster.
Stop Service
Stop a specified service in the cluster.
Restart Service
Restart a specified service in the cluster.
If a service is restarted, other services that depend on this service will be unavailable. Therefore, select Restart upper-layer services. Determine whether to perform this operation based on the displayed service list. Services are restarted one by one due to their dependency. Table 4 describes the restart duration of a single service.
Service Rolling Restart
Restart a specified service in the cluster without interrupting services. For details about the parameter settings, see Table 1.
  • Enable new configuration parameters for a specified service in the cluster.
  • Distribute new configuration parameters for services whose Configuration Status is Expired.
After some services are synchronized, restart the services for the settings to take effect.
Table 4 Restart duration for reference
Service
Restart Duration
Startup Duration
Remarks
IoTDB
3 min
IoTDBServer: 3 min
CDL
2 min
CDLConnector: 1 min
CDLService: 1 min
ClickHouse
4 min
ClickHouseServer: 2 min
ClickHouseBalancer: 2 min
HDFS
10min+x
NameNode: 4 min + x
DataNode: 2 min
JournalNode: 2 min
Zkfc: 2 min
x indicates the NameNode metadata loading duration. It takes about 2 minutes to load 10,000,000 files. For example, x is 10 minutes for 50 million files. The startup duration fluctuates with reporting of DataNode data blocks.
Yarn
5 min + x
ResourceManager: 3 min + x
NodeManager: 2 min
x indicates the time required for restoring ResourceManager reserved tasks. It takes about 1 minute to restore 10,000 reserved tasks.
MapReduce
2 min + x
JobHistoryServer: 2 min + x
x indicates the scanning duration of historical tasks. It takes about 2.5 minutes to scan 100,000 tasks.
ZooKeeper
2 min + x
quorumpeer: 2 min + x
x indicates the duration for loading znodes. It takes about 1 minute to load 1 million znodes.
Hive
3.5 min
HiveServer: 3 min
MetaStore: 1 min 30s
WebHcat: 1 min
Hive service: 3 min
Spark2x
5 min
JobHistory2x: 5 min
SparkResource2x: 5 min
JDBCServer2x: 5 min
Flink
4 min
FlinkResource: 1 min
FlinkServer: 3 min
Kafka
2 min + x
Broker: 1 min + x
x indicates the data restoration duration. It takes about 2 minutes to start 20,000 partitions for a single instance.
Storm
6 min
Nimbus: 3 min
UI: 1 min
Supervisor: 1 min
Logviewer: 1 min
Flume
3 min
Flume: 2 min
MonitorServer: 1 min
Doris
2 min
FE: 1min
BE: 1min
DBroker: 1min
