Managing Monitoring Metric Reports
On FusionInsight Manager, you can customize monitoring items to display on the homepage and export monitoring data.
![](https://support.huaweicloud.com/intl/en-us/usermanual-mrs/public_sys-resources/note_3.0-en-us.png)
The interval on the horizontal axis of the chart varies depending on the time period you specify. Data monitoring rules are as follows:
- If the disk usage of the partition where GaussDB is deployed exceeds 80%, real-time monitoring data and monitoring data whose interval is 5 minutes will be deleted.
- Storage resources (HDFS) in Tenant Resources (0 to 300 hours): The interval is 1 hour. The cluster must have been installed for at least 1 hour, and monitoring data of a maximum of 3 months is saved.
- 0 to 25 hours: The interval is 5 minutes. The cluster must have been installed for at least 10 minutes, and monitoring data of a maximum of 15 days is saved.
- 25 to 150 hours: The interval is 30 minutes. The cluster must have been installed for at least 30 minutes, and monitoring data of a maximum of 3 months is saved.
- 150 to 300 hours: The interval is 1 hour. The cluster must have been installed for at least 1 hour, and monitoring data of a maximum of 3 months is saved.
- 300 hours to 300 days: The interval is 1 day. The cluster must have been installed for at least 1 day, and monitoring data of a maximum of 6 months is saved.
- Over 300 days: The interval is 7 days. The cluster must have been installed for more than 7 days, and monitoring data of a maximum of 1 year is saved.
Customizing a Monitoring Metric Report
- Choose Homepage.
- In the upper right corner of the chart area, click
and choose Customize from the displayed menu.
Monitoring data of the past 1 hour is displayed at an interval of 5 minutes. After you enter the Real-time Monitoring page, you can view that real-time monitoring data is displayed on the right of the monitoring chart at an interval of 5 minutes.
- In the left pane of the Customize Statistics dialog box, select a resource to monitor.
- Select one or multiple monitoring metrics in the right pane.
Figure 1 Customizing a monitoring metric report
- Click OK.
Exporting All Monitoring Data
- Choose Homepage.
- In the upper right corner of the chart area, select a time range to obtain monitoring data, for example, 1w.
Real-time data is displayed by default, which cannot be exported. You can click
to customize a time range.
Figure 2 Customizing a time range - In the upper right corner of the chart area, click
and choose Export from the displayed menu.
Exporting Monitoring Data of a Specified Monitoring Item
- Choose Homepage.
- Click
in the upper right corner of any monitoring report pane in the chart area of the target cluster.
- Select a time range to obtain monitoring data, for example, 1w.
Figure 3 Customizing a time range for a specified monitoring item - Click Export.
