Help Center > > User Guide> FusionInsight Manager Operation Guide (Applicable to 3.x)> Getting Started> Logging In to FusionInsight Manager
Updated at: Oct 21, 2021 GMT+08:00
This section describes how to log in to FusionInsight Manager using an account after FusionInsight Manager is installed.
  1. Obtain the URL of FusionInsight Manager.
  2. On login page, enter the username and password.
  3. New users need to change their passwords.
    Figure 1 Change Password
    The password must meet the following requirements:
    • It must contain 8 to 64 characters.
    • It must contain at least four of the following character types: uppercase letters, lowercase letters, digits, spaces, and special characters `~!@#$%^&*()-_=+|[{}];',<.>/\?.
    • It must be different from the username or its reverse.
    • It must be different from the current password.
  4. Move your cursor to in the upper right corner of FusionInsight Manager, and click Log Out and and click OK from the drop-down list to log out of the current user.
Did you find this page helpful?
Submit successfully!
Thank you for your feedback. Your feedback helps make our documentation better.
Failed to submit the feedback. Please try again later.
Which of the following issues have you encountered?
Please complete at least one feedback item.
Content most length 200 character
Content is empty.
OK Cancel
