Updated on 2025-07-28 GMT+08:00
Using the Web Interface
If you have obtained the IP address of the hard terminal, you can quickly configure the hard terminal by following the configuration wizard on the web interface.
  1. Log in to the web interface and choose System Settings > Wizard. The Wizard page is displayed, as shown in Figure 1. Configure parameters based on Table 1.
    Figure 1 General and IP address settings
    Table 1 General and IP address settings
    Site name
    Uniquely identifies a site.
    Connection type
    Specifies the mode in which the terminal obtains an IP address.
    • Static IP: The network administrator assigns an IP address to the terminal. If you select this option, you must also set Local IP address, Subnet mask, and Gateway address.
    • Dynamic IP: When a DHCP server is available on the network, the terminal automatically obtains an IP address using DHCP.
    The WAN is a service network used to transmit service data. The LAN is a maintenance network used for device maintenance.
  2. Click Next. On the Server Settings page that is displayed, set Cloud platform to Huawei Cloud and click Activate. In the dialog box that is displayed, enter the activation code.
    If the system displays a message indicating that the server fails to be obtained, reset the terminal settings and activate the terminal again. For details about how to reset the settings, see Routine Maintenance > Restoring Factory Settings in HUAWEI Bar Maintenance Guide.
    If the terminal still cannot be activated after the settings are reset, contact Huawei Cloud customer service at +86 4000-955-988 or 950808 and forward the call to technical support as prompted.
  3. Click Next. The Video Input page is displayed, as shown in Figure 2. Set parameters based on Table 2.
    Figure 2 Video input
    The input port configurations of the Box series are similar. Here, the port configuration of the Box 900 is used as an example. For details about the input ports of each terminal type, click in the upper right corner to view the online help.
    Table 2 Video input
    How to Configure
    Remote control
    Specifies whether a remote site can control the local camera during a call.
    The default value is Allow.
    Video source management
    Specifies whether a remote site can select the video source of this terminal on the camera control interface.
    Selecting an incorrect video source may result in black screens. Therefore, you are advised to use the default value.
    The default value is Do not allow.
    Powered by endpoint from
    Specifies the port from which the terminal supplies power to the connected device. Two options are available: HD-VI and HDBaseT.
    The default value is HD-VI.
    Dual-VPT300 mode
    Specifies whether to enable the dual-VPT300 mode when the terminal has two VPT300s connected. If you select this option, the two VPT300s connected to the terminal work at the same time. If you do not select this option, the VPT300 connected to the video input interface specified by Main output interface works.
    This parameter is unavailable on the web interface of the Box 500.
    The default value is Disable.
    This function and the AI virtual sign-in function under System Settings > AI Settings cannot be enabled at the same time. The AI virtual sign-in function is disabled by default.
    Track when not in conference
    If the Enable option is selected, the tracking function of the VPT300 will work even when the terminal is not in any meetings.
    Camera 1
    Specifies the input port for the terminal to connect to camera 1 of VPT300.
    This parameter is available only when Dual-VPT300 mode is set to Enable.
    Camera 2
    Specifies the input port for the terminal to connect to camera 2 of VPT300.
    The default value for the Box 700 is 4 12G-SDI.
    The default value for the Box 900 is 5 12G-SDI.
    Serial port
    Specifies the serial port that is connected to the camera control interface.
    The default value is None.
    Camera type
    Specifies the type of the camera connected.
    The default value is VPC600/VPC620.
    Initial position
    Specifies the position of the camera after startup.
    • Auto: The camera moves to its initial position after startup.
    • Preset 1: The camera moves to the preset after startup.
    The default value is Auto.
    Movement speed
    Specifies the movement and zoom speed for the camera at your site.
    • Select Slow for accurate positioning.
    • Select Fast for quick positioning.
    • Select Medium for medium paced positioning.
    The default value is Medium.
    Stretch mode
    Specifies how your terminal adjusts the input video based on the video encoding format.
    • Stretch: Stretch the video to the full-screen mode without locking the aspect ratio of the video.
    • No stretch: Stretch the video to full screen with a fixed aspect ratio. Black borders may appear at the edges of the display.
    The default value is No stretch.
    Mirroring
    Specifies whether the terminal displays a reflection of an input video, wherein the right and left sides of the original are reversed.
    • Normal: The input video will not be reversed.
    • Horizontal mirroring: The terminal displays a reflection of the input video, wherein the right and left sides of the original are reversed like the reflection of something seen in a mirror.
    The default value is Normal.
  4. Click Finish.
  5. Check the hard terminal version.
    Choose Help > Version and check whether the software version of your meeting terminal is the recommended version V600R019C00SPC800. If not, contact the meeting terminal provider to upgrade the software version.
