Help Center/ Elastic Load Balance/ User Guide/ User Guide for Shared Load Balancers/ Load Balancer/ Enabling Guaranteed Performance for a Shared Load Balancer
Updated on 2025-05-09 GMT+08:00
Guaranteed performance allows shared load balancers to handle up to 50,000 concurrent connections, 5,000 new connections per second, and 5,000 queries per second. It provides you with more stable and reliable load balancing capabilities in case of traffic surge.
If your shared load balancers were created after February 10, 2023, guaranteed performance will be enabled for them by default.
If your shared load balancers were created before February 10, 2023, perform the following operations to enable guaranteed performance.
Notes
  • Guaranteed performance cannot be disabled once enabled.
  • After guaranteed performance is enabled, shared load balancers will be billed on a pay-per-use basis. For details about product prices, see Product Pricing Details.
  1. Go to the load balancer list page.
  2. Locate the target shared load balancer and click its name to enter the Summary page.
  3. Click Enable.
  4. Click Enable Now.
    Figure 1 Enabling guaranteed performance
