System Rules
Table 1 lists the system inspection rules supported by DLI.
Default system rules are SQL inspection rules automatically created by DLI when a queue is created. These rules are bound to the queue and cannot be deleted.
Default system rules include Scan files number, Scan partitions number, Count(distinct) occurrences, and Not in<Subquery>.
Only one inspection rule can be created for an action or a queue.
For every supported action, a default system rule is created. For example, when a queue is created, a Scan files number rule is automatically created for both the Info and Block actions.
Rule ID |
Rule Name |
Description |
Type |
Applicable Engine |
Action |
Value |
Default System Rule |
Example SQL Statement |
dynamic_0001 |
Scan files number |
Maximum number of files to be scanned |
Dynamic |
Spark trino |
Info Block |
Value range: 1–2000000 Default value: 200000 |
Yes |
N/A |
dynamic_0002 |
Scan partitions number |
Maximum number of partitions involved in the operations (select, delete, update, and alter) that can be performed on a table |
Dynamic |
Spark |
Info Block |
Value range: 1–500000 Default value: 5000 |
Yes |
DELETE FROM table_name WHERE column_name = value |
running_0002 |
Memory used(MB) |
Peak memory usage of the SQL statement |
Running |
Spark |
Circuit Breaker |
Value range: 1–8388608 |
No |
N/A |
running_0003 |
Run time(S) |
Maximum running duration of the SQL statement |
Running |
Spark |
Circuit Breaker |
Unit: second Value range: 1–43200 |
No |
N/A |
running_0004 |
Scan data(GB) |
Maximum amount of data to be scanned |
Running |
Spark |
Circuit Breaker |
Unit: GB Value range: 1–10240 |
No |
N/A |
static_0001 |
Count(distinct) occurrences |
Maximum number of occurrences of count(distinct) in the SQL statement |
Static |
Spark |
Info Block |
Value range: 1–100 Default value: 10 |
Yes |
SELECT COUNT(DISTINCT deviceId), COUNT(DISTINCT collDeviceId) FROM table GROUP BY deviceName, collDeviceName, collCurrentVersion; |
static_0002 |
Not in<Subquery> |
Check whether not in <subquery> is used in the SQL statement. |
Static |
Spark |
Info Block |
Value range: Yes, No Default value: Yes |
Yes |
SELECT * FROM Orders o WHERE Orders.Order_ID not in (Select Order_ID FROM HeldOrders h where h.order_id = o.order_id); |
static_0003 |
Join occurrences |
Maximum number of joins in the SQL statement |
Static |
Spark |
Info Block |
Value range: 1–50 |
No |
SELECT name, text FROM table_1 JOIN table_2 ON table_1.Id = table_2.Id |
static_0004 |
Union occurrences |
Maximum number of union all times in the SQL statement |
Static |
Spark |
Info Block |
Value range: 1–100 |
No |
select * from tables t1 union all select * from tables t2 union all select * from tables t3 |
static_0005 |
Subquery nesting layers |
Maximum number of subquery nesting layers |
Static |
Spark |
Info Block |
Value range: 1–20 |
No |
select * from ( with temp1 as (select * from tables) select * from temp1); |
static_0006 |
Sql size(KB) |
Maximum size of a SQL file |
Static |
Spark |
Info Block |
Unit: KB Value range: 1–1024 |
No |
N/A |
static_0007 |
Cartesian product |
Limitation of Cartesian products when multiple tables are being associated |
Static |
Spark |
Info Block |
Value range: 0–1 |
No |
select * from A,B; |
