DLI Package
Introduction
You can buy DLI resources in a more affordable price if you buy DLI packages. The billing mode of the packages depends on their types. A package provides resource quotas that you pay before you use. If the quotas are finished, billing switches to pay-per-use.
Package Types
- CUH package for an elastic resource pool: The usage is billed based on the number of CUHs used for running jobs on the queues you add to an elastic resource pool.
- Data package: The usage is billed based on the amount of data scanned (GB) in each job.
- CUH package for a queue: The usage is billed based on the number of CUHs used for running jobs on your queue.
- Storage package: The usage is billed based on the amount (unit: GB) of data stored in DLI.
Package Usage Notes
- A package is bound to a specific region. A purchased package can be used in the bound region only.
- The resources in the package are preferentially used during billing. After the package quotas are finished, the excess part will be billed on a pay-per-use basis.
- The package cannot be refunded after being purchased.
- If your package expires, you can still use DLI resources and you will be billed on a pay-per-use basis.
Buying a DLI Package
- Log in to the DLI management console.
- In the navigation pane on the left, choose Resources > Queue Management.
- On the Queue Management page, click Buy DLI Package.
- On the Buy DLI Package page, configure required parameters.
Table 1 Parameters required for buying a package Parameter
Region
Select a region. Select a region near you to ensure the lowest latency possible.
Project
Each region corresponds to a project.
Package Type
- Elastic resource pool CUH: The usage is billed based on the number of CUHs used for running jobs on the queues you add to an elastic resource pool.
- Scanned data volume: The usage is billed based on the amount of data scanned by each job (unit: GB).
- Queue CUH: The usage is counted based on the number of CUHs used for running jobs on your queue.
- Storage: The usage is billed based on the amount (unit: GB) of data stored in DLI.
Specifications
Package specifications
Required Duration
Validity period of the package
Quantity
Number of packages you want to buy
- Confirm the package information, select the check box of the notice, and click Buy.
