Monitoring Metrics
This section describes DCC metrics reported to Cloud Eye as well as their namespaces and dimensions. You can use Cloud Eye to view these metrics and alarms generated for DCC.
Currently, Cloud Eye is available only in some regions for monitoring DCC. For details, see the management console.
Namespace
SYS.DCC
Metrics
| Metric ID | Name | Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Period (Raw Data) |
| host_cpu_usage | Host CPU Allocation Rate | CPU allocation rate of a host | 0-100 | % | N/A | dedicated_host_id | 5 minutes |
| host_mem_usage | Host Memory Allocation Rate | Memory allocation rate of a host | 0-100 | % | N/A | dedicated_host_id | 5 minutes |
| cluster_cpu_usage | Resource Pool CPU Allocation Rate | CPU allocation rate of a resource pool | 0-100 | % | N/A | dedicated_cluster_id | 5 minutes |
| cluster_mem_usage | Resource Pool Memory Allocation Rate | Memory allocation rate of a resource pool | 0-100 | % | N/A | dedicated_cluster_id | 5 minutes |
Dimensions
| Key | Value |
| dedicated_host_id | Host ID. To obtain the value, log in to the Cloud Eye console and choose Cloud Service Monitoring > Dedicated Computing Cluster > Host. |
| dedicated_cluster_id | Cluster ID. To obtain the value, log in to the Cloud Eye console and choose Cloud Service Monitoring > Dedicated Computing Cluster > Cluster. |
