Updated on 2024-06-26 GMT+08:00
Service Check
Check Items
After a cluster is upgraded, check whether its services are running properly.
Different services have different verification mode. Select a suitable one and verify the service before and after the upgrade.
You can verify the service from the following aspects:
  • The service page is available.
  • No alarm or event is generated on the normal platform.
  • No error log is generated for key processes.
  • The API dialing test is normal.
Solution
If your online services malfunction after the cluster upgrade, contact technical support.
