SecurityGroups
When the Cloud Native Network 2.0 model is used, pods use VPC ENIs or sub-ENIs for networking. You can directly bind security groups and EIPs to pods. CCE provides a custom resource object named SecurityGroup for you to associate security groups with pods in CCE. You can customize workloads with specific security isolation requirements using SecurityGroups.
Notes and Constraints
- This function is supported for CCE Turbo clusters of v1.19 and later. Upgrade your CCE Turbo clusters if their versions are earlier than v1.19.
- A workload can be bound to a maximum of five security groups.
Using the Console
- In the navigation pane of the CCE console, choose Resource Management > Network.
- On the SecurityGroup tab page, select the target cluster in the upper right corner and click Create.
- Set the parameters as described in Table 1.
Table 1 Configuration parameters Parameter
Example Value
SecurityGroup Name
Enter a SecurityGroup name.
Enter 4 to 63 characters. The value must start with a lowercase letter and cannot end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
security-group
Cluster Name
Select a cluster.
cce-turbo
Namespace
Select a namespace. If the namespace is not created, click Create Namespace.
default
Workload
Select a workload.
nginx
Security Group
The selected security group will be bound to the ENI or supplementary ENI of the selected workload. A maximum of five security groups can be selected from the drop-down list. You must select one or multiple security groups to create a SecurityGroup.
If no security group has not been created, click Create Security Group. After the security group is created, click the refresh button.
NOTICE:- A maximum of 5 security groups can be selected.
- Hover the cursor on the security group name, and you can view details about the security group.
64566556-bd6f-48fb-b2c6-df8f44617953
5451f1b0-bd6f-48fb-b2c6-df8f44617953
- After setting the parameters, click Create.
After the SecurityGroup is created, the system automatically returns to the SecurityGroup list page. You can see that the newly added SecurityGroup is in the list.
Using kubectl
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Create a description file named securitygroup-demo.yaml.
vi securitygroup-demo.yaml
For example, create the following SecurityGroup to bind all nginx workloads with two security groups 64566556-bd6f-48fb-b2c6-df8f44617953 and 5451f1b0-bd6f-48fb-b2c6-df8f44617953 that have been created in advance. An example is as follows:
apiVersion: crd.yangtse.cni/v1 kind: SecurityGroup metadata: name: demo namespace: default spec: podSelector: matchLabels: app: nginx securityGroups: - id: 64566556-bd6f-48fb-b2c6-df8f44617953 - id: 5451f1b0-bd6f-48fb-b2c6-df8f44617953
Table 2 describes the parameters in the YAML file.Table 2 Description Field
Mandatory
apiVersion
API version. The value is crd.yangtse.cni/v1.
Yes
kind
Type of the object to be created.
Yes
metadata
Metadata definition of the resource object.
Yes
name
Name of the SecurityGroup.
Yes
namespace
Name of the namespace.
Yes
Spec
Detailed description of the SecurityGroup.
Yes
podselector
Used to define the workload to be associated with security groups in the SecurityGroup.
Yes
SecurityGroups
Security group ID.
Yes
- Run the following command to create the SecurityGroup:
kubectl create -f securitygroup-demo.yaml
If the following information is displayed, the SecurityGroup is being created.
securitygroup.crd.yangtse.cni/demo created
- Run the following command to view the SecurityGroup:
kubectl get sg
If the name of the created SecurityGroup is demo in the command output, the SecurityGroup is created successfully.
NAME POD-SELECTOR AGE all-no map[matchLabels:map[app:nginx]] 4h1m s001test map[matchLabels:map[app:nginx]] 19m demo map[matchLabels:map[app:nginx]] 2m9s
Other Operations
Operation |
Procedure |
Deletion |
Update |
Viewing the YAML file |
Viewing events |
Provide feedbackFor any further questions, feel free to contact us through the chatbot.
