Updated on 2022-12-01 GMT+08:00
Cluster Permissions (IAM-based)
CCE cluster permissions are assigned based on IAM system policies and custom policies. You can use user groups to assign permissions to IAM users.
Cluster permissions are configured only for cluster-related resources (such as clusters and nodes). You must also configure namespace permissions to operate Kubernetes resources (such as workloads and Services).
  • Before granting permissions to user groups, get familiar with the system policies listed in Permissions Management. For the system policies of other services, see System Permissions.
  • A user with the Security Administrator role (for example, a Huawei Cloud account) has all IAM permissions except role switching. Only these users can view user groups and their permissions on the Permissions Management page on the CCE console.
Configuration
On the CCE console, when you choose Permissions Management > Cluster-Level Permissions to create a user group, you will be directed to the IAM console to complete the process. After the user group is created and its permissions are configured, you can view the information on the Cluster-Level Permissions tab page. This section describes the operations in IAM.
Process Flow
Figure 1 Process of assigning CCE permissions
  1. Create a user group and assign permissions to it.
    Create a user group on the IAM console, and assign CCE permissions, for example, the CCE ReadOnlyAccess policy to the group.
    CCE is deployed by region. On the IAM console, select Region-specific projects when assigning CCE permissions.
  2. Create a user and add it to a user group.
    Create a user on the IAM console and add the user to the group created in 1.
  3. Log in and verify permissions.
    Log in to the management console as the user you created, and verify that the user has the assigned permissions.
    • Log in to the management console and switch to the CCE console. Click Buy Cluster in the upper right corner. If you fail to do so (assuming that only the CCE ReadOnlyAccess role is assigned), the permission policy takes effect.
    • Switch to the console of any other service. If a message appears indicating that you do not have the required permissions to access the service, the CCE ReadOnlyAccess policy takes effect.
System-defined Roles
Roles are a type of coarse-grained authorization mechanism that defines service-level permissions based on user responsibilities. This mechanism provides only a limited number of service-level roles for authorization. However, roles are not an ideal choice for fine-grained authorization and secure access control.
The preset system role for CCE in IAM is CCE Administrator. When assigning this role to a user group, you must also assign other roles and policies on which this role depends, such as Tenant Guest, Server Administrator, and ELB Administrator. For more information about dependencies, see System Permissions.
System-defined Policies
The system policies preset for CCE in IAM are CCE FullAccess and CCE ReadOnlyAccess.
  • CCE FullAccess: common operation permissions on CCE cluster resources, excluding the namespace-level permissions for the clusters (with Kubernetes RBAC enabled) and the privileged administrator operations, such as agency configuration and cluster certificate generation
  • CCE ReadOnlyAccess: permissions to view CCE cluster resources, excluding the namespace-level permissions of the clusters (with Kubernetes RBAC enabled)
Table 1 Permissions assigned by CCEFullAccess
Action
Specific Action
cce:*:*
cce:cluster:create
Create a cluster.
cce:cluster:delete
Delete a cluster.
cce:cluster:update
Update a cluster, for example, update cluster node scheduling parameters and provide RBAC support to clusters.
cce:cluster:upgrade
Upgrade a cluster.
cce:cluster:start
Wake up a cluster.
cce:cluster:stop
Hibernate a cluster.
cce:cluster:list
List all clusters.
cce:cluster:get
Query cluster details.
cce:node:create
Add a cluster node.
cce:node:delete
Delete one or more nodes.
cce:node:update
Update a cluster node, for example, update the node name.
cce:node:get
Query node details.
cce:node:list
List all nodes.
cce:nodepool:create
Create a node pool.
cce:nodepool:delete
Delete a node pool.
cce:nodepool:update
Update information about a node pool.
cce:nodepool:get
Obtain information about a node pool.
cce:nodepool:list
List all node pools in a cluster.
cce:release:create
Create a release.
cce:release:delete
Delete a release.
cce:release:update
Update a release.
cce:job:list
List all cluster jobs.
cce:job:delete
Delete one or more cluster jobs.
cce:job:get
Query a specified cluster job.
cce:storage:create
Create a storage volume.
cce:storage:delete
Delete a storage volume.
cce:storage:list
List all volumes.
cce:addonInstance:create
Create an add-on instance.
cce:addonInstance:delete
Delete an add-on instance.
cce:addonInstance:update
Update an add-on instance.
cce:addonInstance:get
Query add-on instance details.
cce:addonTemplate:get
Query add-on template details.
cce:addonInstance:list
List all add-on instances.
cce:addonTemplate:list
List all add-on templates.
cce:chart:list
List all charts.
cce:chart:delete
Delete a chart.
cce:chart:update
Update a chart.
cce:chart:upload
Upload a chart.
cce:chart:get
Obtain information about a chart.
cce:release:get
Obtain information about a release.
cce:release:list
List all releases.
cce:userAuthorization:get
Obtain CCE user authorization.
cce:userAuthorization:create
Create CCE user authorization.
ecs:*:*
Perform all operations on Elastic Cloud Server (ECS).
evs:*:*
Perform all operations on Elastic Volume Service (EVS).
EVS disks can be attached to cloud servers and scaled to a higher capacity whenever needed.
vpc:*:*
Perform all operations on Virtual Private Cloud (VPC), including ELBs.
A cluster must run in a VPC. When creating a namespace, you need to create or associate a VPC for the namespace so that all containers in the namespace will run in the VPC.
sfs:*:get*
View Scalable File Service (SFS) resource details.
sfs:shares:ShareAction
Share SFS resources for scaling.
aom:*:get
View Application Operations Management (AOM) resource details.
aom:*:list
List AOM resources.
aom:autoScalingRule:*
Perform all operations on AOM auto scaling rules.
apm:icmgr:*
Perform operations on the ICAgent in Application Performance Management (APM).
lts:*:*
Perform all operations on Log Tank Service (LTS).
Table 2 Permissions assigned by CCEReadOnlyAccess
Action
Specific Action
cce:*:get
cce:cluster:get
cce:node:get
Query node details.
cce:job:get
cce:chart:get
cce:nodepool:get
cce:release:get
cce:*:list
cce:cluster:list
List all clusters.
cce:node:list
List all nodes.
cce:job:list
cce:chart:list
List all charts.
cce:nodepool:list
cce:release:list
List all releases.
cce:storage:list
List all volumes.
cce:kubernetes:*
Perform operations on all Kubernetes resources. For details, see Namespace Permissions (Kubernetes RBAC-based).
ecs:*:get
View details about all ECS resources.
An ECS with multiple EVS disks is a cluster node in CCE.
ecs:*:list
List all ECS resources.
bms:*:get*
View details about all BMS resources.
bms:*:list
List all BMS resources.
evs:*:get
View details of all EVS disk resources. EVS disks can be attached to cloud servers and scaled to a higher capacity whenever needed.
evs:*:list
List all EVS resources.
evs:*:count
vpc:*:get
View details of all VPC resources (including ELBs).
vpc:*:list
List all VPC resources (including ELBs).
sfs:*:get*
View SFS resource details.
aom:*:get
View AOM resource details.
aom:*:list
List all AOM resources.
lts:*:get
View details about all LTS resources.
lts:*:list
List all LTS resources.
Custom Policies
Custom policies can be created as a supplement to the system-defined policies of CCE. For the actions that can be added to custom policies, see Permissions Policies and Supported Actions.
You can create custom policies in either of the following ways:
  • Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
  • JSON: Edit JSON policies from scratch or based on an existing policy.
For details, see Creating a Custom Policy. This section provides examples of common custom CCE policies.
Example Custom Policies:
  • Example 1: Creating a cluster named test
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "cce:cluster:create"
  • Example 2: Denying node deletion
    A policy with only "Deny" permissions must be used in conjunction with other policies to take effect. If the permissions assigned to a user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
    The following method can be used if you need to assign permissions of the CCEFullAccess policy to a user but you want to prevent the user from deleting nodes (cce:node:delete). Create a custom policy for denying node deletion, and attach both policies to the group to which the user belongs. Then, the user can perform all operations on CCE except deleting nodes. The following is an example of a deny policy:
        "Version": "1.1",
        "Statement": [
                "Effect": "Deny",
                "Action": [
                    "cce:node:delete"
  • Example 3: Defining permissions for multiple services in a policy
    A custom policy can contain the actions of multiple services that are of the global or project-level type. The following is an example policy containing actions of multiple services:
        "Version": "1.1",
        "Statement": [
                "Action": [
                    "ecs:cloudServers:resize",
                    "ecs:cloudServers:delete",
                    "ims:images:list",
                    "ims:serverImages:create"
                "Effect": "Allow"
CCE Cluster Permissions and Enterprise Projects
CCE supports resource management and permission allocation by cluster and enterprise project.
Note that:
  • IAM projects are based on physical isolation of resources, whereas enterprise projects provide global logical groups of resources, which better meet the actual requirements of enterprises. In addition, IAM policies can be managed based on enterprise projects. Therefore, you are advised to use enterprise projects for permissions management. For details, see Creating an Enterprise Project.
  • When there are both IAM projects and enterprise projects, IAM preferentially matches the IAM project policies.
  • When creating a cluster or node using purchased cloud resources, ensure that IAM users have been granted the required permissions in the enterprise project to use these resources. Otherwise, the cluster or node may fail to be created.
CCE Cluster Permissions and IAM RBAC
CCE is compatible with IAM system roles for permissions management. You are advised to use fine-grained policies provided by IAM to simplify permissions management.
CCE supports the following roles:
  • Basic IAM roles:
    • te_admin (Tenant Administrator): Users with this role can call all APIs of all services except IAM.
    • readonly (Tenant Guest): Users with this role can call APIs with the read-only permissions of all services except IAM.
  • Custom CCE administrator role: CCE Administrator
  • CCE APIs are designed compatible with three legacy system roles of ServiceStage (SvcStg Administrator, SvcStg Developer, and SvcStg Operator). Currently, CCE and ServiceStage have fully adapted to fine-grained policies of IAM for permissions management. Therefore, you are not advised to use these legacy roles for permissions management. These ServiceStage roles are described as follows:
    • SvcStg Administrator: This role has the same permissions as the CCE Administrator role except that users with this role do not have the namespace-level permissions by default (Kubernetes RBAC).
    • SvcStg Developer: This role has the same permissions as the CCE Administrator role except that the user with this role does not have the namespace-level permission by default (Kubernetes RBAC).
    • SvcStg Operator: This role has the read-only permissions on CCE, excluding the namespace-level permissions of clusters by default.
    For more information about ServiceStage and CCE permissions management, see ServiceStage Permissions Management and CCE Permissions Management.
  • Tenant Administrator and Tenant Guest are special IAM system roles. After any system or custom policy is configured, Tenant Administrator and Tenant Guest take effect as system policies to achieve compatibility with IAM RBAC and ABAC scenarios.
  • If a user has the Tenant Administrator or CCE Administrator system role, the user has the cluster-admin permissions in Kubernetes RBAC and the permissions cannot be removed after the cluster is created.
    If the user is the cluster creator, the cluster-admin permissions in Kubernetes RBAC are granted to the user by default. The permissions can be manually removed after the cluster is created.
    • Method 1: Choose Permissions Management > Namespace-Level Permissions > Delete at the same role as cluster-creator on the CCE console.
    • Method 2: Delete ClusterRoleBinding: cluster-creator through the API or kubectl.
When RBAC and IAM policies co-exist, the backend authentication logic for open APIs or console operations on CCE is as follows:
Certain CCE APIs involve namespace-level permissions or key operations and therefore, they require special permissions:
Using clusterCert to obtain the cluster kubeconfig: cceadm/teadmin
