Using a Temporary Custom Access Key (AK/SK) to Mount an OBS Volume
In containerized application deployment, mounting an OBS bucket into a container still requires a permanent AK/SK. Because these credentials never expire, they broaden the blast radius of any leak and clash with the least-privilege policies that security-focused enterprises now enforce. The container-storage add-on (CCE Container Storage (Everest)) eliminates the need for permanent AK/SKs by generating a short-lived, custom AK/SK each time an OBS volume is mounted. Unlike the permanent AK/SKs held by IAM users, these credentials are created on demand, expire in 15 minutes to 24 hours, and are then automatically deleted, eliminating the long-term risk of a leaked key.
- The cluster version must meet the following requirements:
- v1.28: v1.28.10-r0 or later
- v1.31: v1.31.10-r0 or later
- v1.32: v1.32.6-r0 or later
- Clusters of later versions
- When an OBS volume is mounted using a temporary custom AK/SK, you must periodically refresh that credential before it expires. Otherwise, service containers will not be able to access the mounted OBS volume.
- The temporary AK/SK inherits the exact OBS read/write permissions of the IAM user who requested it, so that user must already hold those rights.
Creating a Secret Using an Access Key
- Obtain temporary access keys (AK/SK and STS token). For details, see Temporary Access Key (for Federated Users).
- Encode each credential in Base64. (Assume that the AK is xxx, the SK is yyy, and the STS token is zzz.)
echo -n xxx|base64 echo -n yyy|base64 echo -n zzz|base64 -w 0
Record the encoded AK/SK and STS token.
- Create a YAML file, for example test-user.yaml, to hold the secret.
apiVersion: v1 data: access.key: WE5WWVhVNU***** secret.key: Nnk4emJyZ0***** security.token: Adfaf***** kind: Secret metadata: name: test-user namespace: default labels: secret.kubernetes.io/used-by: csi type: cfe/secure-opaqueThe parameters are as follows.
access.key
The Base64-encoded AK
secret.key
The Base64-encoded SK
security.token
The Base64-encoded STS token
name
The secret name
namespace
The namespace of the secret
The label required so the console can use this secret when provisioning an OBS PV/PVC.
type
Secret type. The value must be cfe/secure-opaque.
When this type is used, user input is encrypted automatically.
- Create the secret.
kubectl create -f test-user.yaml
Associating a Secret with an OBS Volume
The method of associating a secret with an OBS volume varies depending on how the volume was created.
After a secret is created using the AK/SK, you can associate the secret with the PV to be created and then use the AK/SK in the secret to mount an OBS volume.
- Log in to the OBS console, create an OBS bucket, and record the bucket name and storage class. The parallel file system is used as an example.
- Create a YAML file for the PV, for example, pv-example.yaml.
apiVersion: v1 kind: PersistentVolume metadata: name: pv-obs-example annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner spec: accessModes: - ReadWriteMany capacity: storage: 1Gi csi: nodePublishSecretRef: name: test-user namespace: default driver: obs.csi.everest.io fsType: obsfs volumeAttributes: everest.io/obs-volume-type: STANDARD everest.io/region: ap-southeast-1 storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner volumeHandle: obs-normal-static-pv persistentVolumeReclaimPolicy: Delete storageClassName: csi-obsParameter
Secret specified during the mounting.
- name: name of the secret
- namespace: namespace of the secret
fsType
File type. The value can be obsfs or s3fs. If the value is s3fs, an OBS bucket is created and mounted. If the value is obsfs, an OBS parallel file system is created and mounted.
volumeHandle
OBS volume name.
- Create a PV.
kubectl create -f pv-example.yaml
After a PV is created, you can create a PVC and associate it with the PV.
- Create a YAML file for the PVC, for example, pvc-example.yaml.
Example YAML file for the PVC:
apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: csi.storage.k8s.io/node-publish-secret-name: test-user csi.storage.k8s.io/node-publish-secret-namespace: default volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner everest.io/obs-volume-type: STANDARD csi.storage.k8s.io/fstype: obsfs name: obs-secret namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 1Gi storageClassName: csi-obs volumeName: pv-obs-exampleParameter
Secret name
Namespace of the secret
- Create a PVC.
kubectl create -f pvc-example.yaml
After the PVC is created, you can create a workload and associate it with the PVC to create volumes.
When dynamically creating an OBS volume, you can use the following method to specify a secret:
apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: csi.storage.k8s.io/node-publish-secret-name: test-user csi.storage.k8s.io/node-publish-secret-namespace: default everest.io/obs-volume-type: STANDARD csi.storage.k8s.io/fstype: obsfs name: obs-secret namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 1Gi storageClassName: csi-obsParameter
Secret name
- Create a PVC.
Verification
- Query the name of the workload pod.
kubectl get po | grep obs-secret
Expected outputs:
obs-secret-5cd558f76f-vxslv 1/1 Running 0 3m22s
- Query the objects in the mount path. In this example, the query is successful.
- Write data into the mount path. In this example, the write operation failed.
kubectl exec obs-secret-5cd558f76f-vxslv -- touch /temp/test
Expected outputs:
touch: setting times of '/temp/test': No such file or directory command terminated with exit code 1
- Set the read/write permissions for the IAM user who mounted the OBS volume by referring to the bucket policy configuration.
- Write data into the mount path again. In this example, the write operation succeeded.
- Check the mount path in the container to see whether the data is successfully written.
kubectl exec obs-secret-5cd558f76f-vxslv -- ls -l /temp/
Expected outputs:
-rwxrwxrwx 1 root root 0 Jun 7 01:52 test
