Updated on 2026-09-15 GMT+08:00
Configuring an EIP for a Pod
In CCE Autopilot clusters, pods use elastic network interfaces or supplementary network interfaces for networking so you can directly bind EIPs to pods.
To bind an EIP to a pod, simply set the value of the yangtse.io/pod-with-eip annotation to true when creating the pod. Then, the EIP is automatically allocated and bound to the pod.
  • To access a pod with an EIP bound from the Internet, you need to add security group rules to allow the Internet traffic to the pod.
  • Only one EIP can be bound to a pod.
  • Configure the EIP-related annotation when creating a pod. After the pod is created, the annotations related to the EIP cannot be modified.
  • Do not perform operations on the EIP associated with a pod through the EIP console or API. Otherwise, the EIP may malfunction. The operations include changing the EIP name, deleting, unbinding, or binding the EIP, and changing the billing mode of the EIP.
  • After an automatically allocated EIP is manually deleted, the network malfunctions. In this case, rebuild the pod.
Allocating an EIP During Pod Creation
When creating a pod, set the pod-with-eip annotation to true. An EIP will be automatically allocated and bound to the pod.
The following uses a Deployment named nginx as an example. For details about annotations, see Table 2.
  • For an EIP that is automatically allocated when you create a Deployment and has a dedicated bandwidth, you do not need to specify the bandwidth ID. The following shows an example:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/pod-with-eip: "true"  # An EIP will be automatically allocated when the pod is created.
            yangtse.io/eip-bandwidth-size: "5"  # EIP bandwidth
            yangtse.io/eip-network-type: 5_bgp  # EIP type
            yangtse.io/eip-charge-mode: bandwidth  # EIP billing mode
            yangtse.io/eip-bandwidth-name: <eip_bandwidth_name>  # EIP bandwidth name
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 250m
                  memory: 500Mi
                requests:
                  cpu: 250m
                  memory: 500Mi
          imagePullSecrets:
            - name: default-secret
    Table 1 Annotations for an EIP with a dedicated bandwidth
    Annotation
    Mandatory
    Default Value
    Value
    Yes
    false
    Whether to bind an EIP to a pod
    false or true
    No
    5
    Bandwidth, in Mbit/s
    The value range varies depending on the region and bandwidth billing mode. For details, see the purchase page on the EIP console.
    For example, in the CN East-Shanghai1 region, if an EIP is billed by bandwidth, the bandwidth ranges from 1 Mbit/s to 2,000 Mbit/s; if an EIP is billed by traffic, the bandwidth ranges from 1 Mbit/s to 300 Mbit/s.
    No
    5_bgp
    EIP type
    The types vary by region. For details, see the EIP console.
    For example, the following types are supported in the CN East-Shanghai1 region:
    • 5_bgp: dynamic BGP
    • 5_sbgp: static BGP
    No
    None
    Billed by traffic or bandwidth
    You are advised to configure this parameter. If this parameter is left blank, no billing mode is specified. In this case, the default value of the EIP API in the region is used.
    • bandwidth: billed by bandwidth
    • traffic: billed by traffic
    No
    Pod name
    Bandwidth name
    Enter 1 to 64 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
  • For an EIP that is automatically allocated when you create a Deployment and has a shared bandwidth, you are required to specify the bandwidth ID. The following shows an example:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/eip-bandwidth-id: <eip_bandwidth_id>  # Shared bandwidth ID of the EIP
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 250m
                  memory: 500Mi
                requests:
                  cpu: 250m
                  memory: 500Mi
          imagePullSecrets:
    Table 2 Annotations for an EIP with a shared bandwidth
    Annotation
    Mandatory
    Default Value
    Value
    Yes
    false
    false or true
    No
    5_bgp
    EIP type
    • 5_bgp
    • 5_union
    • 5_sbgp
    Mandatory when a shared bandwidth is used
    None
    ID of an existing bandwidth
    • If this parameter is not specified, the EIP with a dedicated bandwidth is used by default. For details about parameter settings for an EIP with a dedicated bandwidth, see Table 1.
    • Only the yangtse.io/eip-network-type field can be specified concurrently, and this field is optional.
Checking Whether the EIP Bound to the Pod Is Available
After an EIP is allocated to a pod, the container networking controller binds the EIP to the pod and writes the allocation result back to the pod's yangtse.io/allocated-ipv4-eip annotation. The startup time of the pod's service containers may be earlier than the time when the EIP allocation result is written back.
You can configure an init container for the pod, associate the yangtse.io/allocated-ipv4-eip annotation with the init container through a downwardAPI volume, and check whether the EIP has been allocated in the init container. You can configure the init container as follows:
apiVersion: v1
kind: Pod
  annotations:
    yangtse.io/eip-bandwidth-name: "xxx"
  initContainers:
  - name: init
    image: busybox:latest
    command: ['timeout', '60', 'sh', '-c', "until grep -E '[0-9]+' /etc/eipinfo/allocated-ipv4-eip; do echo waiting for allocated-ipv4-eip; sleep 2; done"]
    volumeMounts:
        - name: eipinfo
          mountPath: /etc/eipinfo
  volumes:
    - name: eipinfo
      downwardAPI:
        items:
          - path: "allocated-ipv4-eip"
            fieldRef:
              fieldPath: metadata.annotations['yangtse.io/allocated-ipv4-eip']
Deleting an EIP Together with a Pod
When you delete a pod, the EIP automatically allocated to the pod will also be released.
