Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Clusters/ Upgrade Management/ Troubleshooting for Pre-upgrade Check Exceptions/ SSH Connectivity of Master Nodes
Updated on 2024-11-08 GMT+08:00
Check Items
Check whether your master nodes can be accessed using SSH.
Solution
There is a low probability that the SSH connectivity check fails due to network fluctuations. Perform the pre-upgrade check again.
If the check still fails, submit a service ticket to contact technical support.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
