CAE Operations Supported by CTS
With CTS, you can record operations associated with CAE for future query, audit, and backtrack operations.
After CTS is enabled, the system starts recording operations on CAE resources. You can view the operation records of the last seven days on the CTS console.
| Operation | Resource Type | Event Name |
| Creating a component | component | createComponent |
| Deleting a component | component | deleteComponent |
| Upgrading a component | component | upgradeComponent |
| Starting a component | component | startComponent |
| Stopping a component | component | stopComponent |
| Restarting a component | component | restartComponent |
| Scaling a component | component | scaleComponent |
| Rolling back a component | component | rollbackComponent |
| Deploying a component | component | deployComponent |
| Configuring a component | component | configureComponent |
| Deleting a component instance | componentInstance | deleteComponentInstance |
| Retrying a job | job | retryJob |
| Creating a VPC to access the CAE environment | network | createNetworkConfiguration |
| Deleting the VPC for accessing the CAE environment | network | deleteNetworkConfiguration |
| Creating a monitoring system configuration | monitorFileSystemConfiguration | createMonitorFileSystemConfiguration |
| Modifying a monitoring system configuration | monitorFileSystemConfiguration | modifyMonitorFileSystemConfiguration |
| Remotely log in to the console | remoteConsole | createRemoteConsole |
| Creating a notification rule | noticeRules | createNoticeRules |
| Updating a notification rule | noticeRules | updateNoticeRules |
| Updating URL monitoring | urlMonitor | updateUrlMonitor |
| Updating a security configuration | secrets | updateSecrets |
| Deleting a security configuration | secrets | deleteSecrets |
| Creating a security configuration | secrets | createSecrets |
| Buying a package | orders | createOrder |
| Adding a CAE environment to access a VPC | network | createNetworkConfiguration |
| Deleting a CAE environment to access a VPC | network | deleteNetworkConfiguration |
| Creating an EIP | eip | createEnvironmentElasticIP |
| Deleting an EIP | eip | deleteEnvironmentElasticIP |
| Waking up an environment | environment | wakeupEnvironment |
| Creating a network access configuration | ingressConfig | createIngressConfig |
| Deleting a network access configuration | ingressConfig | deleteIngressConfig |
| Updating a network access configuration | ingressConfig | updateIngressConfig |
| Creating an application | application | createApplication |
| Deleting an application | application | deleteApplication |
| Creating an environment | environment | createEnvironment |
| Deleting an environment | environment | deleteEnvironment |
| Binding cloud storage | cloudStorage | bindCloudStorage |
| Unbinding cloud storage | cloudStorage | unbindCloudStorage |
| Creating a certificate | Certificate | createCertificate |
| Updating a certificate | Certificate | updateCertificate |
| Deleting a certificate | Certificate | deleteCertificate |
| Creating a domain name | Domain | createDomain |
| Deleting a domain name | Domain | deleteDomain |
| Creating a scheduled start/stop policy | TimerRules | createTimerRules |
| Updating a scheduled start/stop policy | TimerRules | updateTimerRules |
| Deleting a scheduled start/stop policy | TimerRules | deleteTimerRules |
