Component Overview
An application component implements a service feature of an application. It is in the form of code or software packages and can be deployed independently.
After creating an application on CAE, you can create components in the application.
Component Description
Table 1 lists the languages and runtime systems supported by CAE components.
| Runtime System | Component Source |
| Java 8, Java 11, Java 17, Java 21 | Source code repository and JAR package |
| Tomcat 8, Tomcat 9 | Source code repository and WAR package |
| Node.js 8, Node.js 14, Node.js 16 | Source code repository and ZIP package |
| PHP 7, PHP 8 | Source code repository and ZIP package |
| Docker | Image package |
| Python 3 | Source code repository and ZIP package |
| .net core | Source code repository |
Component Source
| Component Source | Description |
| Source code repository | GitHub, GitCode, GitLab, and Bitbucket code can be identified. |
| Image | If you use a private image to create your containerized application, upload the private image to the image repository. The following upload modes are supported:
CAE container-based deployment does not support images of the Arm architecture. |
| Software package | The following upload modes are supported:
