Help Center/ Bare Metal Server/ User Guide/ Key Pairs and Passwords/ Deleting the Password of a Windows BMS
Updated on 2025-11-28 GMT+08:00
To ensure security, you are advised to delete the initial password recorded in the system.
Deleting the initial password does not affect BMS operation or login. Once deleted, the password cannot be retrieved. Before deleting a password, you are advised to record it.
  1. Log in to the BMS console.
  2. Locate the target BMS in the BMS list.
  3. In the Operation column, click More and select Delete Password.
    The following dialog box is displayed.
    Figure 1 Warning
  4. Click OK to delete the password.
