Disk Types
Huawei Cloud provides various storage products for your BMSs, including block storage based on the distributed storage architecture, dedicated storage based on enterprise storage architecture, and local disks.
- Block storage refers to EVS disks, which are block-based storage products and adopt a three-copy distributed mechanism. EVS disks provide high reliability, performance, and scalability. You can create or release them at any time.
 - Dedicated Distributed Storage Service (DSS) provides dedicated physical storage resources and adopts a three-copy distributed mechanism similar to block storage. It provides high availability and durability, and stable and low latency using multiple technologies, such as data redundancy and cache acceleration.
 - Local disks include NVMe SSDs, SATA disks, and others. They provide a low latency, high throughput, and high cost-effectiveness and are applicable to scenarios that have large volumes of data and require high storage I/O performance and real-time performance.
Because local disks of a single physical server may encounter a single point of failure (SPOF), you are advised to configure data redundancy at the application layer to ensure data availability.
       Storage Product  |
       Storage Type  |
       Typical Application Scenarios  |
       Process  |
       Block storage  |
       Shared storage pools  |
       Create a disk and then attach the disk to the BMS.  |
       DSS  |
       Physically isolated storage pools and dedicated resources  |
       DSS can be used with BMSs in DeCs or those not in DeCs.
       Local disks  |
       Local disks of servers  |
       Create a BMS and use its local disks directly.  |
