Key BMS Operations Supported by CTS
Cloud Trace Service (CTS) is a log audit service provided by Huawei Cloud and intended for cloud security. It allows you to collect, store, and query cloud resource operation records and use these records for security analysis, compliance auditing, resource tracking, and fault locating.
You can use CTS to record BMS operations for later querying, auditing, and backtracking.
You need to enable CTS before using it. If it is not enabled, BMS operations cannot be recorded. After being enabled, CTS automatically creates a tracker to record all your operations. The tracker stores only the operations of the last seven days. To store the operations for a longer time, store trace files in OBS buckets. For details, see Overview.
BMS Operations Recorded by CTS
| Operation | Resource | Trace Name |
| Creating a BMS | bms | createBareMetalServers |
| Deleting a BMS | bms | deleteBareMetalServers |
| Starting a BMS | bms | startBareMetalServers |
| Stopping a BMS | bms | stopBareMetalServers |
| Restarting a BMS | bms | rebootBareMetalServers |
