Binding a Virtual IP Address to a BMS
You can bind a virtual IP address to a BMS for connection redundancy. This section describes how to bind a virtual IP address to a BMS.
What Is a Virtual IP Address?
Virtual IP addresses, also called floating IP addresses, are used for active and standby switchover of servers to achieve high availability. If the active server is faulty and cannot provide services, the virtual IP address is dynamically switched to the standby server to provide services.
If you want to improve service high availability and avoid single points of failure, you can use BMSs that are deployed to work in the active/standby mode or one active and multiple standby modes. These BMSs use the same virtual IP address.
- Bind two BMSs in the same subnet to the same virtual IP address.
- Configure Keepalived for the two BMSs to work in the active/standby mode. For details about Keepalived configurations, see the common configuration methods in the industry.
- Log in to the BMS console.
- Click the name of the BMS to which a virtual IP address needs to be bound.
- Click the NICs tab. Then, click Manage Virtual IP Address.
The page showing details of the particular VPC is displayed.
- On the Virtual IP Address tab, select a desired one or click Assign Virtual IP Address for a new one.
- Click Bind to Server in the Operation column and select the target BMS and the NIC to bind the virtual IP address to the NIC.
