Help Center/ Bare Metal Server/ User Guide/ Network/ User-defined VLAN/ Configuring a User-defined VLAN (SUSE Linux Enterprise Server 12)
Updated on 2025-07-18 GMT+08:00
The network segment of the user-defined VLAN cannot overlap the network information configured on the BMS.
This section uses SUSE Linux Enterprise Server 12 SP1 (x86_64) as an example to describe how to configure a user-defined VLAN for BMSs.
  1. Use a key or password to log in to the BMS as user root.
  2. On the BMS CLI, run the following command to check the NIC information:
    ip link
    Information similar to the following is displayed.
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    2: eth0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 8888 qdisc mq master bond0 state UP mode DEFAULT group default qlen 1000
        link/ether fa:16:3e:3d:1c:e0 brd ff:ff:ff:ff:ff:ff
    3: eth1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 8888 qdisc mq master bond0 state UP mode DEFAULT group default qlen 1000
    4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
        link/ether 38:4c:4f:89:55:8d brd ff:ff:ff:ff:ff:ff
    5: eth3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
        link/ether 38:4c:4f:89:55:8e brd ff:ff:ff:ff:ff:ff
    6: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 8888 qdisc noqueue state UP mode DEFAULT group default
    7: bond0.3133@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 8888 qdisc noqueue state UP mode DEFAULT group default
        link/ether fa:16:3e:57:87:6e brd ff:ff:ff:ff:ff:ff
    Among the devices, eth0 and eth1 bear the VPC, and eth2 and eth3 bear the user-defined VLAN.
  3. Configure the udev rules:
    Run the following command to create the 80-persistent-net.rules file:
    cp /etc/udev/rules.d/70-persistent-net.rules /etc/udev/rules.d/80-persistent-net.rules
    Write the NIC MAC address and name that are queried in 2 and that are not displayed in 80-persistent-net.rules to the file. In this way, after the BMS is restarted, the NIC name and sequence will not change.
    Ensure that the NIC MAC address and name are lowercase letters.
    vim /etc/udev/rules.d/80-persistent-net.rules
    The modification result is as follows:
    SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="38:4c:4f:29:0b:e0", NAME="eth0"
    SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="38:4c:4f:29:0b:e1", NAME="eth1"
    SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="38:4c:4f:89:55:8d", NAME="eth2"
    SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="38:4c:4f:89:55:8e", NAME="eth3"
    After the modification, save the change and exit.
  4. Run the following command to check the NIC IP address:
    ifconfig
    Information similar to the following is displayed, where bond0 and bond0.313 show the NIC IP addresses automatically allocated by the system when you apply for the BMS:
    bond0     Link encap:Ethernet  HWaddr FA:16:3E:3D:1C:E0
              inet addr:10.0.1.2  Bcast:10.0.1.255  Mask:255.255.255.0
              inet6 addr: fe80::f816:3eff:fe3d:1ce0/64 Scope:Link
              UP BROADCAST RUNNING MASTER MULTICAST  MTU:8888  Metric:1
              RX packets:852 errors:0 dropped:160 overruns:0 frame:0
              TX packets:1121 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:125429 (122.4 Kb)  TX bytes:107221 (104.7 Kb)
    bond0.313 Link encap:Ethernet  HWaddr FA:16:3E:57:87:6E
              inet addr:10.0.3.2  Bcast:10.0.3.255  Mask:255.255.255.0
              inet6 addr: fe80::f816:3eff:fe57:876e/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:8888  Metric:1
              RX packets:169 errors:0 dropped:0 overruns:0 frame:0
              TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:8684 (8.4 Kb)  TX bytes:1696 (1.6 Kb)
    eth0      Link encap:Ethernet  HWaddr FA:16:3E:3D:1C:E0
              UP BROADCAST RUNNING SLAVE MULTICAST  MTU:8888  Metric:1
              RX packets:428 errors:0 dropped:10 overruns:0 frame:0
              TX packets:547 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:64670 (63.1 Kb)  TX bytes:50132 (48.9 Kb)
    eth1      Link encap:Ethernet  HWaddr FA:16:3E:3D:1C:E0
              RX packets:424 errors:0 dropped:7 overruns:0 frame:0
              TX packets:574 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:60759 (59.3 Kb)  TX bytes:57089 (55.7 Kb)
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:65536  Metric:1
              RX packets:8 errors:0 dropped:0 overruns:0 frame:0
              TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:520 (520.0 b)  TX bytes:520 (520.0 b)
  5. Run the following commands to check the names of bonded NICs:
    The in-service bonded NICs cannot be used on the internal communication plane. Therefore, you must obtain them by name.
    cd /etc/sysconfig/network
    vi ifcfg-bond0
    Information similar to the following is displayed, where bond0 is composed of NICs eth0 and eth1:
    BONDING_MASTER=yes
    TYPE=Bond
    STARTMODE=auto
    BONDING_MODULE_OPTS="mode=4 xmit_hash_policy=layer3+4 miimon=100"
    NM_CONTROLLED=no
    BOOTPROTO=dhcp
    DEVICE=bond0
    USERCONTRL=no
    LLADDR=fa:16:3e:3d:1c:e0
    BONDING_SLAVE1=eth1
    BONDING_SLAVE0=eth0
    After the query, exit.
  6. Run the following commands to check the statuses of all NICs:
    ip link
  7. Run the following commands to change the NIC status qdisc mq state DOWN to qdisc mq state UP. The following commands use NICs eth2 and eth3 as examples.
    ip link set eth2 up
    ip link set eth3 up
  8. Run the following commands to check the statuses of all NICs:
    ip link
    4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
    5: eth3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
  9. Check the statuses of the NICs in 8 and obtain the names of the NICs in qdisc mq state UP state.
    Only the NICs that are in qdisc mq state UP state and have not been used can be bonded. In this example, such NICs are eth2 and eth3.
    The LLADR values of NICs eth2 and eth3 are 38:4c:4f:89:55:8d and 38:4c:4f:89:55:8e, respectively.
  10. Run the following commands to create the configuration files of NICs eth2 and eth3:
    You can copy an existing NIC configuration file and modify it to improve the creation efficiency.
    cp ifcfg-eth0 ifcfg-eth2
    cp ifcfg-eth1 ifcfg-eth3
  11. Run the following commands to modify the configuration files of NICs eth2 and eth3:
    vi ifcfg-eth2
    vi ifcfg-eth3
    Modified configuration file of NIC eth2 is as follows.
    In this configuration file, set MTU to 8888, BOOTPROTO to STATIC, and configure DEVICE and LLADDR as needed.
    STARTMODE=auto
    MTU=8888
    NM_CONTROLLED=no
    BOOTPROTO=STATIC
    DEVICE=eth2
    USERCONTRL=no
    LLADDR=38:4c:4f:89:55:8d
    TYPE=Ethernet
    Modified configuration file of NIC eth3 is as follows:
    STARTMODE=auto
    MTU=8888
    NM_CONTROLLED=no
    BOOTPROTO=STATIC
    DEVICE=eth3
    USERCONTRL=no
    LLADDR=38:4c:4f:89:55:8e
    TYPE=Ethernet
  12. Run the following command to bond NICs eth2 and eth3 to a NIC, for example, bond1:
    Run the following commands to create the ifcfg-bond1 file and modify the configuration file:
    cp ifcfg-bond0 ifcfg-bond1
    vi ifcfg-bond1
    Modified configuration file of NIC bond1 is as follows.
    In this configuration file, MTU is set to 8888, BONDING_MODULE_OPTS is set to mode=1 miimon=100, BOOTPROTO is set to STATIC. DEVICE, BONDING_SLAVE1, BONDING_SLAVE0, IPADDR, NETMASK, and NETWORK are configured as required. LLADDR is set to the LLADDR value of the BONDING_SLAVE1 NIC.
    BONDING_MASTER=yes
    TYPE=Bond
    MTU=8888
    STARTMODE=auto
    BONDING_MODULE_OPTS="mode=1 miimon=100"
    NM_CONTROLLED=no
    BOOTPROTO=STATIC
    DEVICE=bond1
    USERCONTRL=no
    BONDING_SLAVE1=eth2
    BONDING_SLAVE0=eth3
    IPADDR=10.0.2.2
    NETMASK=255.255.255.0
    NETWORK=10.0.2.0
  13. Make the configuration file take effect.
    1. Run the following commands to create a temporary directory and copy the NIC configuration file to this directory:
      mkdir /opt/tmp/
      mkdir /opt/tmp/xml
      cp /etc/sysconfig/network/ifcfg* /opt/tmp/
      cp /etc/sysconfig/network/config /opt/tmp/
      cp /etc/sysconfig/network/dhcp /opt/tmp/
    2. Run the following commands to stop NICs to form bond1:
      ip link set eth2 down
      ip link set eth3 down
    3. Run the following command to convert the NIC configuration file to a configuration file that can be recognized by the OS:
      /usr/sbin/wicked --log-target=stderr --log-level=debug3 --debug all convert --output /opt/tmp/xml /opt/tmp/
    4. Run the following commands to restart the NICs to form bond1:
      ip link set eth2 up
      /usr/sbin/wicked --log-target=stderr --log-level=debug3 --debug all ifup --ifconfig /opt/tmp/xml/eth2.xml eth2
      ip link set eth3 up
      /usr/sbin/wicked --log-target=stderr --log-level=debug3 --debug all ifup --ifconfig /opt/tmp/xml/eth3.xml eth3
      /usr/sbin/wicked --log-target=stderr --log-level=debug3 --debug all ifup --ifconfig /opt/tmp/xml/bond1.xml bond1
  14. Run the following command to query IP addresses:
    ip addr show
    An example is provided as follows:
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: eth0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 8888 qdisc mq master bond0 state UP group default qlen 1000
    3: eth1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 8888 qdisc mq master bond0 state UP group default qlen 1000
    4: eth2: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 8888 qdisc mq master bond1 state UP group default qlen 1000
    5: eth3: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 8888 qdisc mq master bond1 state UP group default qlen 1000
    6: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 8888 qdisc noqueue state UP group default
        inet 10.0.1.2/24 brd 10.0.1.255 scope global bond0
        inet6 fe80::f816:3eff:fe3d:1ce0/64 scope link
    7: bond0.3133@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 8888 qdisc noqueue state UP group default
        inet 10.0.3.2/24 brd 10.0.2.255 scope global bond0.3133
        inet6 fe80::f816:3eff:fe57:876e/64 scope link
    8: bond1: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 8888 qdisc noqueue state UP group default
        inet 10.0.2.2/24 brd 10.0.2.255 scope global bond1
        inet6 fe80::3a4c:4fff:fe29:b36/64 scope link
  15. Run the following commands to delete the temporary directory:
    cd /opt
    rm -rf tmp/
  16. Repeat the preceding operations to configure other BMSs.
