Obtaining the One-Click Password Reset Plug-In
If the password of a BMS failed to be reset, this may be because the one-click password reset plug-in has not been installed on the BMS. Obtain the plug-in and verify its integrity.
Then, you can install the plug-in as instructed in Installing the One-Click Password Reset Plug-in.
Obtain the One-Click Password Reset Plug-In and Verifying Its Integrity (Linux)
- Log in to the BMS as user root.
- Download the one-click password reset plug-in and SHA256 checksum.
Obtain the download address from Obtain the One-Click Password Reset Plug-In and SHA256 Checksum based on the region and OS (32- or 64-bit).
Example commands to download the plug-in and SHA256 checksum for a 32-bit x86 BMS in the CN North-Beijing1 region:
wget https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip
wget https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
- Obtain the hash value of the one-click password reset plug-in.
sha256sum {Software package directory}/CloudResetPwdAgent.zip
Replace Software package directory with the directory where the downloaded plug-in is stored.
- Check whether the SHA256 hash value obtained in step 2 is consistent with that obtained in step 3.
Obtain the One-Click Password Reset Plug-In and Verifying Its Integrity (Windows)
- Log in to the BMS.
Obtain the download address from Obtain the One-Click Password Reset Plug-In and SHA256 Checksum based on the region where the BMS resides.
- Open Command Prompt as an administrator and run the following command to obtain the hash value of the plug-in:
certutil –hashfile {Software package directory}\CloudResetPwdAgent.zip SHA256
| Region | OS | Name | How to Obtain |
| CN North-Beijing1 | Linux(x86_32) | CloudResetPwdAgent.zip | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip |
| SHA256 checksum | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(x86_64) | CloudResetPwdAgent.zip | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(aarch64) | CloudResetPwdAgent.zip | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Windows | CloudResetPwdAgent.zip | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| CN North-Beijing4 | Linux(x86_64) | CloudResetPwdAgent.zip | https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip |
| SHA256 checksum | https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Windows | CloudResetPwdAgent.zip | https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| CN East-Shanghai2 | Linux(x86_32) | CloudResetPwdAgent.zip | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip |
| SHA256 checksum | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(x86_64) | CloudResetPwdAgent.zip | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(aarch64) | CloudResetPwdAgent.zip | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Windows | CloudResetPwdAgent.zip | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| CN South-Guangzhou | Linux(x86_32) | CloudResetPwdAgent.zip | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip |
| SHA256 checksum | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(x86_64) | CloudResetPwdAgent.zip | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(aarch64) | CloudResetPwdAgent.zip | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Windows | CloudResetPwdAgent.zip | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| CN-Hong Kong | Linux(x86_32) | CloudResetPwdAgent.zip | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip |
| SHA256 checksum | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(x86_64) | CloudResetPwdAgent.zip | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(aarch64) | CloudResetPwdAgent.zip | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Windows | CloudResetPwdAgent.zip | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| AP-Bangkok | Linux(x86_32) | CloudResetPwdAgent.zip | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip |
| SHA256 checksum | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(x86_64) | CloudResetPwdAgent.zip | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Linux(aarch64) | CloudResetPwdAgent.zip | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 | ||
| Windows | CloudResetPwdAgent.zip | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip | |
| SHA256 checksum | https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256 |
