Viewing O&M Logs
Introduction
If an exception occurs when you use a BCS instance, view the O&M logs to analyze and locate the fault for quick rectification. This section describes how to view the O&M logs of each BCS instance node in the CCE cluster on the frontend GUI and backend virtual machines (VMs).
| Component | Description | Log Path |
| baas-agent | Blockchain management run log | /var/paas/sys/log/baas-agent/baas-agent.log /var/paas/sys/log/baas-agent/audit.log |
| peer | Peer run log | /var/paas/sys/log/baas-service/peer/audit.peer-******-*.log /var/paas/sys/log/baas-service/peer/peer-******-*.trace |
| orderer | Orderer run log | /var/paas/sys/log/baas-service/orderer/audit.orderer-******-*.log /var/paas/sys/log/baas-service/orderer/orderer-******-*-start.trace /var/paas/sys/log/baas-service/orderer/orderer-******-*.trace |
Viewing Logs on the Frontend GUI
- View and record the node name on the Workloads page of the CCE console.
- Choose Workloads > Deployments, click the cluster where the BCS instance is deployed. View and record the name of the baas-agent node, for example, baas-agent. Figure 1 Checking baas-agent node name
- Choose Workloads > StatefulSets, click the cluster where the BCS instance is deployed. View and record the orderer and peer node names, for example, peer-xx. Figure 2 Checking peer and orderer nodes
- Go to the AOM console to view logs.
- In the navigation pane on the left of the AOM console, choose Log > Log Files, and select the cluster where the BCS instance is located.
- Select a recorded node name, and click View in the Operation column to view the node logs.
- Click Enable Real-Time Viewing. Then, you can view O&M logs of the node in real time.
Viewing O&M Logs on a Backend VM
- On the CCE console, view and record the node name on the Workloads page. For details, see Viewing Logs on the Frontend GUI.
- On the Instance Management page of the BCS console, locate the instance and choose More > Change Access Address to view the access address. The node where the BCS instance is deployed must be bound with an EIP.Figure 3 Changing the blockchain network access address
Figure 4 Viewing the access address
- Log in to the VM corresponding to the access address, and view the O&M logs. Figure 5 Logging to the VM
Enter the VM address (the access address obtained in 2) for Remote host, and enter the VM username for Specify username.- Check baas-agent node logs.
- Run the following command to query the baas-agent node ID:
docker ps|grep baas-agent
Figure 6 Checking the baas-agent node ID
- Run the following command to query the baas-agent node logs:
docker logs ID -f
Figure 7 Checking the baas-agent node logs
- Check the logs of a peer node.
- Run the following command to query the peer node ID:
docker ps|grep peer
Figure 8 Checking the peer ID
- Run the following command to query the peer node logs:
docker logs -f ID
Figure 9 Checking the peer logs
- Check the logs of an orderer node.
- Run the following command to query the orderer ID:
docker ps|grep orderer
Figure 10 Checking the orderer ID
- Run the following command to query the orderer logs:
docker logs -f ID
Figure 11 Checking the orderer logs
