Updated on 2023-10-25 GMT+08:00
max
This function is used to return the maximum value.
Syntax
max(col)
Parameters
Table 1 Parameter
Mandatory
Type
col
Yes
Any type except BOOLEAN
The value can be of any type except BOOLEAN.
Return Values
The return value is of the DOUBLE type.
The return type is the same as the type of col. The return rules are as follows:
  • If the value of col is NULL, the row is not involved in calculation.
  • If the value of col is of the BOOLEAN type, it cannot be used for calculation.
Example Code
  • Calculates the maximum inventory (items) of all offerings. An example command is as follows:
    select max(items) from warehouse;
    The command output is as follows:
    _c0
    900
  • When used with group by, it returns the maximum inventory of each warehouse. An example command is as follows:
    select warehourseId, max(items) from warehouse group by warehourseId;
    warehouseId _c1
    city1    200
    city2    300
    city3    400
