Help Center>
Data Lake Insight>
SQL Syntax Reference (To Be Offline)>
Spark SQL Syntax Reference (Unavailable Soon)>
Built-in Functions>
Date Functions>
current_timestamp
Updated on 2023-10-25 GMT+08:00
current_timestamp
This function is used to return the current timestamp.
Syntax
current_timestamp()
Parameters
None
Return Values
The return value is of the TIMESTAMP type.
Example Code
The value 1692002816300 is returned.
select current_timestamp();
Parent topic: Date Functions
