variance/var_pop
This function is used to return the variance of a column.
Syntax
variance(col), var_pop(col)
Parameters
Parameter | Mandatory | Description |
col | Yes | Columns with a data type of numeric. If the value is of any other type, NULL is returned. |
Return Values
The return value is of the DOUBLE type.
Example Code
- Calculates the variance of all offering inventories (items). An example command is as follows:
select variance(items) from warehouse; -- It is equivalent to the following statement: select var_pop(items) from warehouse;
The command output is as follows:
_c0 203.42352
- When used with group by, it groups all offerings by warehouse (warehouseId) and returns the variance of the offering inventory (items) in the same group. An example command is as follows:
select warehouseId, variance(items) from warehourse group by warehouseId; -- It is equivalent to the following statement: select warehouseId, var_pop(items) from warehourse group by warehouseId;
1 2 3 4
warehouseId _c1 city1 19.23124 city2 17.23344 city3 12.43425
