hour
This function is used to return the hour (from 0 to 23) of a specified time.
Syntax
hour(string date)
Parameters
| Parameter | Mandatory | Type | Description |
| date | Yes | DATE or STRING | Date that needs to be processed The following formats are supported:
Return Values
The return value is of the INT type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
Example Code
The value 10 is returned.
select hour('2023-08-10 10:54:00'); The value 12 is returned.
select hour('12:00:00'); The value NULL is returned.
select hour('20230810105600'); The value NULL is returned.
select hour(null);
