exp
This function is used to return the value of e raised to the power of a.
Syntax
exp(DOUBLE a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | DOUBLE, BIGINT, DECIMAL, or STRING | The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 7.38905609893065 is returned.
select exp(2);
The value 20.085536923187668 is returned.
select exp(3);
The value NULL is returned.
select exp(null);
