day/dayofmonth
This function is used to return the day of a specified date.
Syntax
day(string date), dayofmonth(string date)
Parameters
Parameter | Mandatory | Type | Description |
date | Yes | DATE or STRING | Date that needs to be processed The following formats are supported:
Return Values
The return value is of the INT type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
Example Code
The value 1 is returned.
select day('2023-08-01'); The value NULL is returned.
select day('20230816'); The value NULL is returned.
select day(null);
