avg
This function is used to return the average value.
Syntax
avg(col), avg(DISTINCT col)
Parameters
| Parameter | Mandatory | Type | Description |
| col | Yes | All data types | The value can be of any data type and can be converted to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type.
If the value of col is NULL, the column is not involved in calculation.
Example Code
- Calculates the average number of items across all warehouses. An example command is as follows:
select avg(items) from warehouse;
The command output is as follows:
_c0 100.0
- Calculates the average inventory of all items in each warehouse when used with group by. An example command is as follows:
select warehouseId, avg(items) from warehourse group by warehouseId;
warehouseId _c1 city1 155 city2 101 city3 194
