Querying an Oracle Table
Function
This statement is used to query data in an Oracle table.
Syntax
SELECT * FROM table_name LIMIT number; |
Keywords
LIMIT is used to limit the query results. Only INT type is supported by the number parameter.
Precautions
If schema information is not specified during table creation, the query result contains the _id field for storing _id in the DOC file.
Example
Querying data in the test_oracle table
SELECT * FROM test_oracle limit 100; |
