Updated on 2024-07-04 GMT+08:00
Creating a DLI Table and Associating It with Oracle
Function
This statement is used to create a DLI table and associate it with an existing Oracle table.
  • Before creating a DLI table and associating it with Oracle, you need to create an enhanced datasource connection.
    For details about operations on the management console, see Enhanced Datasource Connections.
  • Only enhanced datasource connections can be used to connect to Oracle, and only pay-per-use and yearly/monthly queues support enhanced datasource connections. So, only SQL jobs on pay-per-use and yearly/monthly queues can be connected to Oracle databases.
Syntax
3
4
5
6
7
8
9
CREATE TABLE [IF NOT EXISTS] TABLE_NAME
  USING ORACLE OPTIONS (
  'url'='xx',
  'driver'='DRIVER_NAME',
  'dbtable'='db_in_oracle.table_in_oracle',
  'user' = 'xxx',
  'password' = 'xxx',
  'resource' = 'obs://rest-authinfo/tools/oracle/driver/ojdbc6.jar'
Keywords
Table 1 CREATE TABLE keywords
url
URL of the Oracle database.
The URL can be in either of the following format:
  • Format 1: jdbc:oracle:thin:@host:port:SID, in which SID is the unique identifier of the Oracle database.
  • Format 2: jdbc:oracle:thin:@//host:port/service_name. This format is recommended by Oracle. For a cluster, the SID of each node may differ, but their service name is the same.
driver
Oracle driver class name: oracle.jdbc.driver.OracleDriver
dbtable
Name of the table associated with the Oracle database or Username.Table name, for example, public.table_name.
user
Oracle username.
password
Oracle password.
resource
OBS path of the Oracle driver package.
Example: obs://rest-authinfo/tools/oracle/driver/ojdbc6.jar
If the driver JAR file defined in this parameter is updated, you need to restart the queue for the update to take effect.
Example
Creating an Oracle datasource table
3
4
5
6
7
8
9
CREATE TABLE IF NOT EXISTS oracleTest
  'url'='jdbc:oracle:thin:@//192.168.168.40:1521/helowin',
  'driver'='oracle.jdbc.driver.OracleDriver',
  'dbtable'='test.Student',
  'user' = 'test',
  'password' = 'test',
